Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: MPI 51M spindle badly seized
  1. #21
    31,775
    20
    You don't happen to be handy with a lathe, do you? I could see a flywheel replacement out of machined brass...
  2. #22
    It would most likely make a better flywheel than the original. One might have oxidation issues over time with the rubber of the belt but the added mass should be welcome for the flywheel purpose.
    Dwight
