Results 1 to 10 of 17
Thread: Troubleshooting a PS/2 8590
    Default Troubleshooting a PS/2 8590
    So I picked up this machine (along with my sixth Model 95, a 25 286 and a Model 30) for free not too long ago and after a lot of cleaning I've started doing some actual work on them.
    Anyways, the issue is the system simply just does not POST. When powering it on both of the fans and the hard disk spin up, the screen flashes and the three lock lights on the keyboards flash, however nothing appears on screen, the diskette drive doesn't do a seek test and no beep codes are emitted. I've noticed that the light on the CD-ROM drive stays lit (it's an IBM CD-ROM II drive) and oddly enough, when you power the system down there is intermittent crackling from the speaker.
    I've already tried swapping around MCA cards as well as the processor complex and the SIMMs are all 8Mb parity (8x8Mb), so I'm not sure what else to check at this point. Any pointers would be greatly appreciated.
    I'm gathering you've seen this:
    http://ohlandl.ipv7.net/9590/9590_Planar.html
    I'd be suspicious of the RAM. Those machines were very picky....
    Sep 2003
    Ohio/USA
    7,550
    When I first got some IBM PS/2 systems in I also got a bag of IBM/Kingston (I think) 72 pin SIMMs and all had gold plated contacts. OEM RAM tends to not be high capacity like later commodity 72 pin SIMM for normal PCs.
    A quick google search shows this for 8MB sticks:
    8MB 2x36-60ns, 72p SIMM, 5v, FPM , so they are parity.
    Mar 2017
    New Jersey, USA
    468
    iirc, PS/2 systems also used the SIMM Presence Detect pins to identify the module type, and to make things worse different models used the same PD codes to mean different things. As a result, sometimes you need memory modules made for that specific computer because 'generic' modules won't work (they will be mis-recognized as having a different size or speed).
    Quote Originally Posted by T-R-A View Post
    Quote Originally Posted by kgober View Post
    I did see this while I've been working on this system and I did double check the RAM. Every SIMM installed is IBM branded 8Mb, 70NS parity, P/N 71F7011.
    Out of curiosity, I swapped the complex out again and this time it POSTed, albeit with code 0002251B. Turns out there is an issue with this system's complex, which sucks as that means I have to choose between giving it to either this Model 90 or my 8595.
    Edit: A quick search of the error codes page on MCAMafia doesn't have a listing for the above code. Or any code that has "25" making up the first half of the last four digits. Any ideas?
    is there any corrosion to the the connectors? I had a similar issue a while back and a bit of deoxit and a few insertions fixed it. Its a huge connector.
    It is a mistake to think you can solve any major problems just with potatoes.
    Quote Originally Posted by luckybob View Post
    There isn't any corrosion to speak of. I did pop this system's complex into my 8595 and was met with the same symptom of no POST.
    So, I know the RAM is good, I know the complex is good, the hard disk and all of the expansion cards I'm using are good, the fans and hard disk spin up and it's able to throw out a POST code... Well, unless I'm missing something obscure, it sounds like I have a bad planar.
    If we were talking about other manufacturers, I'd look at caps at this point. Even solid tants can die. I've never had a reason to recap a main board, but on the other hand, the floppy drives routinely need them.
    I'd check psu voltages under load while I was poking around inside.
    Feb 2011
    2,176
    10
    Quote Originally Posted by ButINeededThatName View Post
    These codes are not mentioned in my PC Server 500 hardware manual...
    ... any clues on the TAVI pages?
    http://www.tavi.co.uk/ps2pages/ohland/complex.html
    G4UGM
    its a error: http://ps-2.kev009.com/pcpartnerinfo/ctstips/ca7a.htm
    000225XX | 1. System Board |
    | (Check memory. It might be the | Memory |
    | wrong type or wrong speed) (*) | |
    | | Memory Riser Card |
    | | (90) |
    | | System Board |
    | | Processor Board |
    | | (90/95) |
    | | 2. Bus Adapter |
