Results 1 to 5 of 5
Thread: Model 4P: Montezuma Micro CP/M and TRSDOS 6 on same Tandy 5 Meg hard disk?
    Jun 2019
    Philadelphia area
    10
    Default Model 4P: Montezuma Micro CP/M and TRSDOS 6 on same Tandy 5 Meg hard disk?
    It seems
    1) I can put CP/M on heads 0-1 or 0-2 and the Model 4P will boot CP/M from hard disk, but this prevents installation of TRSDOS 6 to the hard disk on the free head(s),
    or
    2) I can I put TRSDOS 6 on the first few head(s) and then CP/M on the remaining free head(s), but then CP/M will not boot from hard drive, only floppy, and will not retain CPMFIX enhancements.
    Am I missing some option to get both OS's on the hard drive?
    Jun 2015
    Sioux Falls SD
    269
    I have created a hard drive with multiple operating systems and MM CP/M booting. There is a sequence that you need to follow. I'm traveling at the moment, but when I get home, I'll find the document I wrote and make it available.
    I made a pdf from the original document for myself some times ago.
    Maybe it will be helpfull - source was HARDRIVE.DOC from MMRSHD.DSK
    http://oldcomputers-ddns.org/public/...or_cpm_2-2.pdf
    Jun 2015
    Sioux Falls SD
    269
    Here is a link to a procedure I developed using a Seagate ST-4038 MFM drive in a Tandy 5 MB enclosure. The key step is to save space at the beginning of the drive for MM CP/M, but create that partition last so it is bootable. For the original 5 MB drive, you will have 4 heads and 153 cylinders.
    https://drive.google.com/file/d/1VEB...ew?usp=sharing
    Jun 2019
    Philadelphia area
    10
    Quote Originally Posted by lafos View Post
    Fantastic! Thank you! I will take a look and see if I can make it work on the standard Radio Shack 5 meg drive.
Tags for this Thread
