Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 42
Thread: 5150 Not Passs Mem Refresh Test
  1. #31
    6,800
    The Supersoft/Landmark diagnostic is known to be misleading in regard to RAM tests, especially for the 16KB-64KB motherboard. Per the 16KB-64KB motherboard specific information at [here], "Under no circumstances, believe that a failure of the '16K CRITICAL MEMORY REGION' test must mean that a chip/s in RAM bank 0 has failed." So, you ignore what the Supersoft/Landmark diagnostic is telling you.
    As for Ruud's diagnostic, up until today, I have only ever run it once, and that was an early version. I have just now pulled out a fully functional 16KB-64KB motherboard from storage, and obtained the latest version of Ruud's diagnostic. Based on what I am seeing the diagnostic display as I selectively remove and reinsert various RAM chips, your bank 0 is now good. The problem now is related to bank 1 (possibly an addressing issue as suggested by Dwight).
    If your bank 0 is now good, as I believe it is, you should see the motherboard start after you have refitted the IBM BIOS chip (assuming that chip is good). Does it start ?
  2. #32
    6,800
    Based on what I am seeing the diagnostic display as I selectively remove and reinsert various RAM chips, ...
    Some (partial) screen shots are at [here].
  3. #33
    Livermore, CA
    407
    Thanks modem7
    In that link just above, I get on my screen what is shown on the third picture. It looks like all ram chips are removed. But they are all there.
    I installed back the 10/27/82 rom, and booted. I get 0455 201. I guess I still have bad ram. I still have 4 chips to replace.
    I also get FC00 ROM - bad cassette basic rom chip. I pulled it and cleaned the pins and still get the same. I guess I need another. But this one is gold covered ceramic one. I bet those are harder to find.
    Atari Falcon030, Atari MSTE, Atari PS3000, STACY 4, 4160STE-CosmosEX, Atari PC1, 400/800/1200XL,800XL,800XE,130XE, XEGS, Apple IIGS, TRS-80 4P, TI 99/4A, Co-Co 3, Amiga 500, C64/128D
  4. #34
    Livermore, CA
    407
    Perhaps I should fill all banks and see what error I get rin 1027/82 rom in?
  5. #35
    Livermore, CA
    407
    Well, shucks,
    I fill all the ram and it boots with ram errors!!!
    Lots of work, and knowledge gained. Still have the FC00 ROM error. Where can I find a rom image I can burn to an eprom?
    Again many many thanks for all the help and hand holding on this and other threads. It's fun and frustrating at the same time.
  6. #36
    6,800
    Quote Originally Posted by KLund1 View Post
    Well, shucks,
    I am sure that you meant "no RAM errors".
    FC000 = BASIC chip U32. There are couple of BASIC sets at [here].
  7. #37
    Livermore, CA
    407
    Yes, too excited to type well.
    NO ram errors!!!
  8. #38
    6,800
    And you have the satisfaction of fixing another motherboard.
    Having a quick look back through the posts, the root cause is multiple bad RAM chips in bank 0. Do you agree? I will add the motherboard failure to the list at [here].
  9. #39
    Livermore, CA
    407
    I think Yes (minus the FF00 error). That is probably true after re-reading the Supersoft bugs. These early boards, as you well know, are hard to diagnose. I would suggest that when the SuperSoft results changed from bits 3 & 6 in error to all all bits in error is when the board probably was working. But I kept removing and socketing additional ram chips.
    To test that correctly I probably would have to refill all ram after each new socket/ram IC after it was soldered in. If I recall, after I changed 3 & 6 is when all bits 'went bad' in Supersoft. And RUUD's was about to move past the first 16k test. So maybe a small foot note in your MOST EXCELLENT minuszero site about this issue might be of use to others.But you get all credit for this fix. I was just the hands doing the directed work
    I am still working on the FC00 error. Possibly more questions...
  10. #40
    6,800
    There were a few contributors. A 'thank you' to Rudd for his diagnostic, an additional tool to assist in regard to RAM issues, particularly given that the RAM component of the Supersoft/Landmark diagnostic is unreliable against a 16KB-64KB type motherboard.
