Results 1 to 6 of 6
Thread: Troubleshooting a Tseng Labs et3000ax
    Default Troubleshooting a Tseng Labs et3000ax
    So I recently picked up this computer, it's got a 486-KVD Motherboard, an AMD AM-486 DX 40 CPU, and a Tseng Labs et3000ax Video Card. When I first booted it up, the screen looked all right, the only problem was that the CMOS battery was obviously dead. I pulled out all the extension cards, cleaned them with compressed air, and the computer and power supply too, and when everything put them back together, the screen looks like this:
    If I press F1, I get this:
    The keyboard works completely, the only issue seems to be the gpu. I tested the monitor on an old laptop I have lying and it works in VGA color mode. There is a jumper on the motherboard that switches between EGA/Mono or Color (default) http://www.elhvb.com/mobokive/archiv...kvd/486kvd.pdf. That didn't change anything either. The DIP switches on the Video Card are correctly set according to the monitor (Color 80x25 (IBM 85xx), I have an IBM 8515) ftp://ftp.oldskool.org/pub/drivers/H.../et3000ax.html
    Is the video card dead? Any ideas of what I could do?
    Sep 2008
    SE MI
    4,039
    6
    Quote Originally Posted by andrei View Post
    Did you replace the CMOS battery? If not, you need to do so.
    Surely not everyone was Kung-fu fighting
    Not yet, but I will soon. Do you think it will solve the graphics issues too?
    I did change it, and now I am greeted by this:20190714_221205.jpg
    Do you have another ISA VGA card you can try so you can eliminate the TSENG as the variable?
    Daniel P. Cayea - The Lyon Mountain Company - Plattsburgh, New York 12901
    Vintage Equipment: IBM 5150 * IBM 5161 * ThinkPad 770ED
    Modern Equipment: MacBook Pro 13 * Alienware M15R3
    Sep 2008
    SE MI
    4,039
    6
    Hopefully the battery was a good one? I would pull all of the cards and clean the contacts, gently, with a pencil eraser. Reinstall the cards and make sure that they are firmly in their sockets and not just jammed. Pull, clean and reset the RAM. Hard to tell at this point what the status of the video card is. Do you have access to another video card, or can you install the card in another PC - possibly a friend's?
Tags for this Thread
