Results 1 to 10 of 18
Thread: Com port not detected
    Apr 2019
    Ottawa, Canada
    14
    Default Com port not detected
    Does anyone know anything about this card? It came with my Compaq Portable and seems to be a COM port.
    The compaq diagnostics do not detect a com port installed though... I am not sure what jumper settings are needed (or if that is the problem).
    Someone else seems to have done some board repair on it as there are a couple wires soldered on.
    Soldered on wires doesn't necessarily indicate a repair. Plenty of boards leave the factory this way.
    This does not look like an RS232 card to me.
    did you lookup all the chips? It does seem to have a serial controller on it. The Intel D8274.
    Maybe itís a proprietary card for some external device? Thatís a heck of a lot of DIPs to manage one COM port
    4,305
    2 RAM chips and a high speed multi-port serial chip plus whatever the large NEC chip is (I can't read it) suggests buffering for multiple devices.
    Probably needs a special driver to do anything.
    Concur. Board revisions and fixes usually wind up getting modifications after they're completed. Sometimes design-engineers find better ways of doing something after manufacture or PCB routing just doesn't pan out the way they thought. We had many designs at Siemens with such a fix.
    Apr 2019
    Ottawa, Canada
    14
    Thanks for all the replies guys, I looked at a few other com/serial boards and it does look like it is much more complicated than a typical serial only board.
    I will talk to person I received the computer from and see if I can jog his memory some more.
    There are no markings on the other side, but the board traces are also all "wrinkled" for lack of a better word. They still look ok but definitly not something I have seen before.
    Apr 2019
    Ottawa, Canada
    14
    The only identification I can see on the board is IBM DE-1A but I haven't been able to look that up.
    The large NEC chip is an 8085.
    Jan 2019
    New Hampshire
    161
    I'm going to guess maybe a network card, or perhaps a terminal interface card for a mainframe system ... is the connector db9? male or female?
    31,794
    That large NEC chip is an 8085 CPU. This isn't a simple comms card.
    Jan 2019
    New Hampshire
    161
    What is written on the ROM(?) chip next to the 8085?? Anything on the back of the board?
