Results 1 to 2 of 2
Thread: Question about monitor pins
    Jan 2011
    Vancouver, BC
    4,989
    3
    Default Question about monitor pins
    I'm a bit weak on the subject of monitors.
    I'm trying to fix this SWTPC terminal I have here. According to the diagrams I've got, the connector for the monitor has four pins used: VID, GND, Vert Sync, Horiz Sync.
    This is basically the setup an IBM 5151 monitor uses, right? Save for the intensity pin? Could I rig up my 5151 to connect to this as a diagnostic? I'm assuming I couldn't use a composite..
    34,592
    I suspect that the SWTPC uses a 15.7KHz horizontal 60 Hz veritcal scanning rate; the 5151 is 18KHz 50 Hz, so no, not quite right. It might work, given that the 5151 lacks a horizontal oscillator per se. You might be better off using the CGA monitor. Pick a color or combination.
