Results 1 to 10 of 17
Thread: 3174 Microcode imaging
    Default 3174 Microcode imaging
    I made an interesting discovery today. After taking another look at the pinout for the 2.4 meg drive, I decided to see what happened when I pulled pin 2 low while the disk was spinning. The drive went from 360 rpm to 180 rpm, which I confirmed with my scope. Additionally, the read data waveform seemed to change a bit but I can't really quantify this.
    Anyway I decided to try imaging the disk in this mode using a pentium machine with the HxC floppy software. With pin 2 jumpered to ground the program successfully read 30 sectors per track with the exception of track 0 side 0 which we had already determined to be formatted normally. In the end I have a 2,441,216 byte image file.
    I tried switching the jumper after the program read track 0 side 0 but the program would only read 15 sectors for the subsequent tracks.
    I suppose with this knowledge, someone could hack up a better solution for reading and emulating these disks.
    edit: I should also mention that I found several EBCDIC strings in the image.
    34,970
    That pretty much agrees with my suspicion--Weltec, back in the day (ca. 1986) offered a rather unsuccessful drive that allowed the use of 1.2MB floppies on a stock PC-XT by switching the spindle speed from 300 (for 360K media) to 180 (for 1.2M media). It was fabulously unsuccessful, lasting less than a year. The drive was a 96 tpi unit, so it had the usual liabilities of the AT double-stepped 360K floppies, though Weltec did offer software to do single-stepped 360K media. Where it really fell down was reading 1.2M media. Recall that the current induced in a disk read head is proportional to the linear speed of the media. At 180 RPM, it just didn't work well. Weltec dropped the HD media claim and just sold the thing as a 360K/720K unit. Good times.
    So the idea isn't dead. Running your drive at 180 RPM should render it compatible with any PC high-density imaging utility. No need for special hardware.
    Emulation may be a problem as the track at 2.4MB is twice as long as a standard 1.2MB one; The usual emulation hardware (e.g. Gotek) may not have enough RAM to do the job.
    Feb 2011
    2,465
    10
    what we still don't know is how the drive knows its a 2.44m disk.....
    G4UGM
    Feb 2011
    2,465
    10
    There is code to go in a GoTek here:-
    https://github.com/9track/FlashFloppy
    I have been using it with some success in a couple of my 3174s...
    G4UGM
    Feb 2017
    Guildford, U.K.
    440
    It's definitely not any physical indication. It must be a test write, seek away, seek back, check what is read is as expected sort of thing, or something similar.
    Feb 2011
    2,465
    10
    Quote Originally Posted by WBST View Post
    I was wondering if its a simple marker on the first track...
    G4UGM
    Feb 2017
    Guildford, U.K.
    440
    I checked and there aren't two "sector 0" holes, no visible physical differences in sleeve. It'd be very IBM to do something like the old 720KB/1.44MB drive test. Maybe there's something about the "Vertical Recording" method needed?
    34,970
    How about "Read ID"? That is, you do what's done on the 5170 BIOS for the 1.2M drives--try a Read ID at one data rate, then the other and adjust accordingly.
    Feb 2011
    2,465
    10
    i believe the first track is 1.2 format for both drives, so a marker in the header?
    G4UGM
    Feb 2017
    Guildford, U.K.
    440
    But then what about formatting blank ED diskettes? That'd be all well and good for pre-formatted diskettes though.
