Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: CGA card issue (freeze)
    32,222
    Only in 80x25 text mode. From the BIOS source:
    ;---- HANDLE COMMON SCROLL SET UP HERE
    SCROLL_POSITION PROC	NEAR
    	CMP	CRT_MODE,2		; TEST FOR SPECIAL CASE HERE
    	JB	N9			; HAVE TO HANDLE 80X25 SEPARATELY
    	CMP	CRT_MODE,3
    	JA	N9
    ;----- 80X25 COLOR CARD SCROLL
    	PUSH	DX
    	MOV	DX,3DAH			; GUARANTEED TO BE COLOR CARD HERE
    	PUSH	AX
    N8:					; WAIT_DISP_ENABLE
    	IN	AL,DX			; GET PORT
    	TEST	AL,8			; WAIT FOR VERTICAL RETRACE
    	JZ	N8			; WAIT_DISP_ENABLE
    	MOV	AL,25H
    	MOV	DL,0D8H			; DX=3D8
    	OUT	DX,AL			; TURN OFF VIDEO
    	POP	AX			; DURING VERTICAL RETRACE
    	POP	DX
    N9:
    	CALL	POSITION		; CONVERT TO REGEN POINTER
    	ADD	AX,CRT_START		; OFFSET OF ACTIVE PAGE
    	MOV	DI,AX			; TO ADDRESS FOR SCROLL
    	MOV	SI,AX			; FROM ADDRESS FOR SCROLL
    	SUB	DX,CX			; DX = # ROWS, # COLS IN BLOCK
    	INC	DH
    	INC	DL			; INCREMENT FOR 0 ORIGIN
    	XOR	CH,CH			; SET HIGH BYTE OF COUNT TO ZERO
    	MOV	BP,CRT_COLS		; GET NUMBER OF COLUMNS IN DISPLAY
    	ADD	BP,BP			; TIMES 2 FOR ATTRIBUTE BYTE
    	MOV	AL,BL			; GET LINE COUNT
    	MUL	BYTE PTR CRT_COLS	; DETERMINE OFFSET TO FROM ADDRESS
    	ADD	AX,AX			; *2 FOR ATTRIBUTE BYTE
    	PUSH	ES			; ESTABLISH ADDRESSING TO REGEN BUFFER
    	POP	DS			; FOR BOTH POINTERS
    	CMP	BL,0			; 0 SCROLL MEANS BLANK FIELD
    	RET				; RETURN WITH FLAGS SET
    SCROLL_POSITION ENDP
    You can see how, if the retrace status is missing, an 80x25 scroll would freeze solid.
    6,055
    So in addition to the contents of the CONFIG.SYS and AUTOEXEC.BAT, also type "MODE CO40" and then see if the scrolling issue persists.
    Jul 2019
    France, Pont--Mousson
    13
    Quote Originally Posted by VileR View Post
    I don't recall, but does the 5160 BIOS check for retrace even in 40-column mode? After all there should be no snow problem there.
    If it doesn't, that could help test for this specific problem at least.
    Yes ! problem solved by 40-column mode ! Thank you for this tips, now I can use my original monitor with CGA card !
