Results 1 to 10 of 14
Thread: PS/2 mouse driver on PS/2 model 30 with 8086 CPU
    Default PS/2 mouse driver on PS/2 model 30 with 8086 CPU
    I bought a PS/2 model 30 (8086 CPU) which has to arrive yet and I'm thinking about buying a PS/2 keyboard and mouse set, relatively new. I didn't even know there were optical PS/2 mice.
    Am I right in assuming that any keyboard will work flawlessly, but I need a DOS driver for the mouse (which doesn't exist)? If I need to use an old mouse that works with the "IBM compatible mouse" driver or something, I might look for that. The system is supposed to be used with a mouse, so... It would be cool to have a mouse for the DOS shell and all that stuff.
    Maybe chances are higher that I could use a modern mouse with Windows. But it seems that I could only run Windows 3.0 in monochrome mode. Using another VGA driver it might be possible to run 320x200 with 16 colors, maybe even 256 colors. I might also test Windows 2.x.
    Mar 2009
    Dublin, CA USA
    2,947
    Any PS/2 Mouse should work, and yes there are DOS mouse drivers. I use CuteMouse - http://cutemouse.sourceforge.net/
    New Zealand
    4,167
    4
    Quote Originally Posted by ADAD8 View Post
    Give Geoworks a shot. Its a gui that will run faster than win3.x
    Thumbs-up for both above posts. CuteMouse is lean and efficient (doesn't hog memory).
    Geos 1.x/2.x was a far better GUI than Windows 2.x/3.x ever conceived of being...Berkley Software (the then owners of Geoworks) didn't have the marketing like the Microsoft behemoth of the day. It had as good a support for printers and far better support for video than Windows ever had. Also 2.x came with it's own integrated "mini office-suite".
    https://tedium.co/2019/06/20/geoworks-geos-history/
    Thanks for your answers. I might try Windows and GEOS. I would love to create a backup of the HDD first / transfer the files to my PC to test some things in DOSBox etc. But because of the proprietary HDD interface I can't connect it to another system, so the only way is copying everything using 720 k floppies, right?
    I'll have to use floppies for getting any software/OS on that machine anyway. Also chances are high the DOS (version 4.01) is Italian. Do I have to reinstall a german/english version or can I change the language?
    Can’t go wrong with the good old Model 30. I’ve got two and I love them.
    Geos looks neat, but I will say I love early versions of Windows. I have an early version of Windows on pretty much all of my systems. I like to call myself a “Windows enthusiast.” I’d kill for a boxed copy of Windows 1.01.
    Is Geos an “Environment” or an operating system (didn’t read too much into that article)? Because the early versions of Windows are not operating systems.
    Compaq - “It simply works better”
    Geos is a GUI (or a shell built on top of DOS) just like every non-NT version of Windows. No disrespect intended, but it was way better than any version of Windows prior to perhaps Win95 (with far fewer resources consumed). It's failure was due to a lack of marketing and the afore mentioned strong-arm tactics by Microsoft. I ran it on a Compaq Portable II long ago and even had dial-up internet (on a 286 processor with 640K of ram)
    None taken. I need to put Geos on something and see what it’s like.
    Quote Originally Posted by compaqportableplus View Post
    The best version of it that I had was "New Deal Office 2000", which was "supposed" to be for 386/486 CPU's, but ran on 286's (and maybe 8088's---never tried). Never had a try at the later version "Breadbox Ensemble", but I'm sure there was little difference. I'm glad to see be spun off to a GitHub project...maybe something still good to come from it.
    https://github.com/bluewaysw/pcgeos
    Oct 2014
    Amsterdam, The Netherlands
    93
    Fujitsu also makes a PS/2 Laser mouse in gray and black
    The only bad thing is that the horizontal scroll only works with the USB connection.
    https://www.fujitsu.com/fts/products...m530-grey.html
    https://www.fujitsu.com/fts/products...530-black.html
    I also have replaced the USB cable on my Fujitsu Laser mouse with the PS/2 cable from a dead PS/2 mouse so i don't have the big adapter sticking out the back of my system's
