Results 1 to 8 of 8
Thread: Custom AMD FX-8300 3.3GHz 8-Core PC 8GB DDR3 ECC 1TB SATA III HDD R5 220 Win8.1
    Default Custom AMD FX-8300 3.3GHz 8-Core PC 8GB DDR3 ECC 1TB SATA III HDD R5 220 Win8.1
    Selling my main PC for an upgrade. It's a custom built AM3+ AMD FX based system. $500 OBO.
    https://www.ebay.com/itm/11384456398...84.m1555.l2649
    1,643
    No offense, but you're not going to get ~$600 for that machine (shipping included.) It's at best worth $250.
    It looks like a bomb went off inside the case, it's dirty and fancy ECC memory adds no value because it has no purpose being in that computer. The inappropriate video card also is a demerit. It also has no upgrade path, an FX9370/9590 isn't an upgrade, it's a dumpster fire. It overheats with even a 240/360mm radiator under full load due to the insane 300W TDP.
    For ~$600, you can build a Ryzen 5 2400G system, which is 50% faster.
    If you cleaned it up, did proper cable management and wrote a better description of what exactly is in the machine, you may be able to get $300 for it.
    Sep 2003
    Ohio/USA
    7,652
    The problem you have is that outside of the motherboard which is a high end AM3+ board people on ebay seem to still pay $100+ for the rest of the system is sub optimal crap.
    PSU has very little amp draw on the 12V line (2 17A or 18A lines if I recall correctly) so it won't drive the decent cards of the AMD FX era.
    The CPU you has is bottom barrel FX, people tend to like the FX8350's with 4Ghz base and very overclockable.
    The video card is bargain basement meant for HTPC or generic desktop use.
    Those systems have 2 memory channels so dual matching RAM is batter then single sticks, and 8MB is low at that. You can pick up new AMD only 16GB (2x DDR3 1600 for $33 on ebay and it is very overclockable.
    The heatsink looks huge (too big for that case) what brand is it? Most machines of that generation used the EVO 212 coolers that can still be found.
    It just looks like you slapped a bunch of left over parts together and expect prices for a well tricked out system.
    Sep 2016
    Shrewsbury, MA
    965
    Definitely not worth that much. I had a really clean fx-6350 system I upgraded from that barely got into the triple digits. It's just older tech, a new quad core will probably outrun it. And those FX series processors suck a lot of power
    Computer is no longer available for sale. Planning on keeping it for school and/or a spare PC.
    Dec 2017
    A planet that's evolving And revolving at nine hundred miles an hour
    427
    I used to have an 9590, its not a hot CPU like so many people claim, have you even owned one? It not less then a factory overclocked 8350.
    Sep 2003
    Ohio/USA
    7,652
    I have a mildy overclocked 8350 (running 4.5ghz) and with the huge heatsint and fan it doesn't get very hot, but pushing one to 5ghz is a different story.
    1,643
    Quote Originally Posted by Mr. Horse View Post
    Have you owned one, because you're dead wrong about it not being a hot CPU.
    I serviced a customer machine a couple of years ago which had an FX9590. It was super unstable, which turns out because it was badly overheating due to having an inadequate cooling solution, just a single 120mm closed loop liquid cooler (which AMD recommended.) Even at idle, the CPU was in the 70-80C range and was thermal throttling under light loads. I had to underclock it all the way down to 3500 MHz and lower the core voltage to get it to stop overwhelming the liquid cooler. The TJunct on this processor is 61C so going over damages the CPU and reduces its lifespan.
    I figured it might be bad thermal paste, but nope, the radiator was smokin hot, even with the fan at full speed.
