Thread: What's the easiest way to develop software for 68k Macs?
    Post What's the easiest way to develop software for 68k Macs?
    Hi there!
    Do you know the easiest way to develop software for 68k Macs?
    I only know one programming language for them, called AppleScript. Can you recommend another?
    Jan 2005
    Principality of Xeon (NJ)
    1,361
    The basic interpreter for macs should be easy enough to find. I imagine there was a basic.compiler. Up the difficulty ladder would be Pascal. Then C. Then assembler.
    It's too early. I recently sold Quick Basic for the Mac. I may have scanned the manuals. I don't have disks or copies, but that can be downloaded from somewhere. It's a compiler.
  3. Default
    Try HyperCard with its scripting language, HyperTalk.
    Nov 2008
    Penticton, B.C.
    190
    I started with Turbo Pascal for Mac, then moved to APW (Apple Programmer's Workshop) which had both Pascal and C++ support. After that I moved to CodeWarrior (I think the last version to support System 7/8/9 was CodeWarrior Pro 8.
    Most of that stuff can be found here: https://www.macintoshrepository.org
    Nov 2008
    Penticton, B.C.
    190
    Also, a lot of the original docs by Apple were in Pascal, since that's what they used internally to build the first couple of Finder/System combos.
