Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Question about Atari ST mouse/joystick ports
    Nov 2016
    Quakertown, Pennsylvania
    368
    Default Question about Atari ST mouse/joystick ports
    I'm in the market for an Atari ST but the overwhelming majority of the ones for sale don't come with a mouse. Does the ST use some kind of ST-specific mouse protocol or is it shared with say, the Amiga? I have an Amiga mouse...
    It uses the same type of mouse as the Amiga (functionally the same as a PC bus/InPort style mouse), but the pinout is different. Many 3rd party mice has a switch to go between ST and Amiga pinouts. You could wire a simple adapter to use an Amiga mouse if needed.
    Feb 2011
    NorthWest England (East Pondia)
    2,241
    10
    There are also various adaptors available that allow the use of a USB mouse.
    G4UGM
    Looking for Analog Computers, Drum Plotters, and Graphics Terminals
    Or really any other common mouse.
    Nov 2016
    368
    I've seen those adapters but none of them look like they'd work with the models that have the mouse ports under the keyboard instead of on the sides?
    Feb 2011
    2,241
    10
    No ST has a mouse port on the side. STEs have analogue joystick ports but little software uses them. I guess you might need an extension cable ....
    https://www.ebay.com/itm/383100307339
    or you can make one with ribbon and a couple of IDC DB9...
    G4UGM
    Nov 2016
    368
    Quote Originally Posted by g4ugm View Post
    I'm confused, where is the mouse port on the original 520ST then? The models with built in floppy drives moved the port under the keyboard.
    Sep 2003
    Ohio/USA
    7,682
    2
    There are 2 joystick ports under the machine labeled 0 and 1. You can use the mouse on port 0.
    These ports are the same standard as the common Atari 2600 sticks.
  9. #9
    Feb 2011
    2,241
    10
    Quote Originally Posted by itsvince725 View Post
    Sorry my bad. Some original STs had the mouse ports where the floppy drives are on the "F" models. I have never seen such a machine but oddly there appears to be at least one on E-Bay now..
    https://www.ebay.com/itm/Atari-520ST...e/303243949097
    at least there is no floppy drive light on the top of the keyboard and the add doesn't mention floppy. This one is described as an ST
    https://www.ebay.com/itm/283538706242
    does appear to be an STF or FM..
    .. one thing to watch out for is that the early STFs had only a single sided 360K drive, and the 720K one makes transfering files to a PC much simpler.
    G4UGM
  10. #10
    Oct 2014
    near frankfurt/m, germany
    917
    No, they are digital, they just support a lot of extra buttons. There you can use a Jagpad.
