Results 1 to 10 of 14
Thread: Question about Atari ST mouse/joystick ports
Hybrid View
Previous Post Previous Post   Next Post Next Post
    Nov 2016
    Quakertown, Pennsylvania
    377
    Default Question about Atari ST mouse/joystick ports
    I'm in the market for an Atari ST but the overwhelming majority of the ones for sale don't come with a mouse. Does the ST use some kind of ST-specific mouse protocol or is it shared with say, the Amiga? I have an Amiga mouse...
    It uses the same type of mouse as the Amiga (functionally the same as a PC bus/InPort style mouse), but the pinout is different. Many 3rd party mice has a switch to go between ST and Amiga pinouts. You could wire a simple adapter to use an Amiga mouse if needed.
    Feb 2011
    NorthWest England (East Pondia)
    2,528
    10
    There are also various adaptors available that allow the use of a USB mouse.
    G4UGM
    Looking for Analog Computers, Drum Plotters, and Graphics Terminals
    Or really any other common mouse.
    Nov 2016
    377
    I've seen those adapters but none of them look like they'd work with the models that have the mouse ports under the keyboard instead of on the sides?
    Feb 2011
    2,528
    10
    No ST has a mouse port on the side. STEs have analogue joystick ports but little software uses them. I guess you might need an extension cable ....
    https://www.ebay.com/itm/383100307339
    or you can make one with ribbon and a couple of IDC DB9...
    G4UGM
