Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: DOS Disk file access help.
  1. #21
    34,970
    18
    That's nice, but if you stick text into [ code ] brackets, I can snip it and trace through it myself, rather than enter each line manually, assemble and determine what's going on.
  2. #22
    I just pasted it so it should be possible just to cut and paste the text, I'm not sure where the code [ ] are to display code the way you have been doing it.
    ; program to load a 61440 byte file from a disk to 3000:0000
    ; program called GETFL
    ; usage: GETFL FILENAME.EXT (xxxxxxxx.xxx)
    cr equ 0dh
    lf equ 0ah
    len equ 61440
    mem equ 3000h
    prog segment
    assume csrog
    org 80h ; Command Tail
    nam_len db ? ; length
    fil_nam db 20h dup (?) ; contents
    org 100h
    start: jmp begin
    fil_han dw ? ; place for file handle
    o_err db cr, lf, 'CANNOT OPEN FILE.', cr, lf, '$'
    r_err db cr, lf, 'CANNOT READ THE FILE', cr, lf, '$'
    display macro string
    mov dx,offset string
    mov ah,09H
    int 21h
    endm
    begin: xor bx,bx
    mov bl,nam_len ; load bl with path name length
    mov fil_nam[bx],0 ; make the ASCIZ string
    lea dx,fil_nam + 1 ; point to path name
    mov ah,3dh ; open file
    mov al,02h ; for read only
    int 21h
    jc o_error
    mov fil_han,ax ; store the file handle
    mov bx,fil_han
    read: mov cx,len ; 61440 bytes to read
    push ds ; save data segment reg
    mov dx,mem
    mov ds,dx ; segment at 3000.
    xor dx,dx ; with zero offset
    mov ah,3fh ; read 61440 bytes
    int 21h
    pop ds
    jc r_error
    jmp close
    o_error:display o_err
    jmp close
    r_error:display r_err
    jmp close
    close: mov bx,fil_han ; again in case bx got altered
    mov ah,3eh ; somehow
    int 21h
    exit: mov ah,4ch
    xor al,al
    int 21H
    prog ends
    end start
  3. #23
    34,970
    18
    Okay, I think I can fix it. Normally, to post verbatim text, you place it between [code] and [/code] markers. Simple!
  4. #24
    34,970
    18
    Okay, I assembled it using MASM 6.14 and it appears to work okay. Note that you need to assemble it in "tiny" model.
    My command line was "ml /AT testa.asm"
    Here's the assembly listing:
    Microsoft (R) Macro Assembler Version 6.14.8444		    08/25/19 16:51:44
    testa.asm						     Page 1 - 1
     = 000D				cr 	equ 	0dh
     = 000A				lf 	equ 	0ah
     = F000				len 	equ 	61440
     = 3000				mem 	equ 	3000h
     0000				prog segment
    					assume cs:prog
     0080 00			nam_len db 	? 	; length
     0081  0020 [			fil_nam db 	20h dup (?) ; contents
            00
    					org 100h
     0100				start:
     0100  EB 31				jmp begin
     0102 0000			fil_han dw 	? ; place for file handle
     0104 0D 0A 43 41 4E 4E		o_err 	db 	cr, lf, 'CANNOT OPEN FILE.', cr, lf, '$'
           4F 54 20 4F 50 45
           4E 20 46 49 4C 45
           2E 0D 0A 24
     011A 0D 0A 43 41 4E 4E		r_err 	db 	cr, lf, 'CANNOT READ THE FILE', cr, lf, '$'
           4F 54 20 52 45 41
           44 20 54 48 45 20
           46 49 4C 45 0D 0A
           24
    					mov 	ah,09H
    	int 	21h
    	endm
    				begin:
    					xor 	bx,bx
     0133					mov 	bl,nam_len 	; load bl with path name length
     0133  33 DB				mov 	fil_nam[bx],0 	; make the ASCIZ string
     0135  2E: 8A 1E 0080 R
     013A  2E: C6 87 0081 R			lea 	dx,fil_nam + 1 	; point to path name
           00
     0140  8D 16 0082 R			mov 	ah,3dh 		; open file
     0144  B4 3D				int 	21h
     0146  B0 02				jc 	o_error
     0148  CD 21				mov 	fil_han,ax 	; store the file handle
     014A  72 1D
     014C  2E: A3 0102 R			mov 	bx,fil_han
    				read:
     0150  2E: 8B 1E 0102 R			mov cx,len 		; 61440 bytes to read
     0155					push 	ds 		; save data segment reg
     0155  B9 F000				mov 	dx,mem
     0158  1E				mov 	ds,dx 		; segment at 3000.
     0159  BA 3000				xor 	dx,dx 		; with zero offset
     015C  8E DA
     015E  33 D2				mov 	ah,3fh 		; read 61440 bytes
    					int 	21h
     0160  B4 3F				pop 	ds
     0162  CD 21				jc 	r_error
     0164  1F				jmp 	close
     0165  72 0B
     0167  EB 12			o_error:
    					display	o_err
     0169					jmp 	close
     0169  BA 0104 R	     1		mov 	dx,offset o_err
     016C  B4 09		     1		mov 	ah,09H
     016E  CD 21		     1		int 	21h
     0170  EB 09			r_error:
    					display r_err
     0172					jmp 	close
     0172  BA 011A R	     1		mov 	dx,offset r_err
     0175  B4 09		     1		mov 	ah,09H
     0177  CD 21		     1		int 	21h
     0179  EB 00			close:
     017B					mov 	ah,3eh 		; somehow
     017B  2E: 8B 1E 0102 R			int 	21h
     0180  B4 3E
     0182  CD 21			exit:
    					mov 	ah,4ch
     0184					xor 	al,al
     0184  B4 4C				int 	21H
     0186  32 C0
     0188  CD 21			prog 	ends
    					end 	start
     018A
    testa.asm						     Symbols 2 - 1
    Macros:
                    N a m e                 Type
    display  . . . . . . . . . . . .	Proc
    Segments and Groups:
                    N a m e                 Size     Length   Align   Combine Class
    prog . . . . . . . . . . . . . .	16 Bit	 018A	  Para	  Private
    Symbols:
                    N a m e                 Type     Value    Attr
    begin  . . . . . . . . . . . . .	L Near	 0133	  prog
    close  . . . . . . . . . . . . .	L Near	 017B	  prog
    cr . . . . . . . . . . . . . . .	Number	 000Dh
    exit . . . . . . . . . . . . . .	L Near	 0184	  prog
    fil_han  . . . . . . . . . . . .	Word	 0102	  prog
    fil_nam  . . . . . . . . . . . .	Byte	 0081	  prog
    len  . . . . . . . . . . . . . .	Number	 F000h
    lf . . . . . . . . . . . . . . .	Number	 000Ah
    mem  . . . . . . . . . . . . . .	Number	 3000h
    nam_len  . . . . . . . . . . . .	Byte	 0080	  prog
    o_error  . . . . . . . . . . . .	L Near	 0169	  prog
    o_err  . . . . . . . . . . . . .	Byte	 0104	  prog
    r_error  . . . . . . . . . . . .	L Near	 0172	  prog
    r_err  . . . . . . . . . . . . .	Byte	 011A	  prog
    read . . . . . . . . . . . . . .	L Near	 0155	  prog
    start  . . . . . . . . . . . . .	L Near	 0100	  prog
    	   0 Warnings
    	   0 Errors
  5. #25
    I have an early version of MASM on my 5155 (I will have to check which one). As I say it assembles fine, but it doesn't actually load the disk file to memory and it reports the cannot open error.
    Is the Tiny model command part of all versions of MASM ? It is not mentioned in the book which describes this method to get the file's effective address.
  6. #26
    34,970
    18
    On early versions of MASM, creating a .COM file involves invoking EXE2BIN to convert the relocatable EXE to an absolute COM file. Perhaps that's what's going on with yours.
    A bit on EXE2BIN
    Later versions of MASM and other compilers can produce .COM files directly.
  7. #27
    A bit on EXE2BIN
    I have EXE2BIN already.
    Nearly all of the programs I have written (but none have used disk access before- except using Debug to help) on the 5155, I have just left them as .EXE's and they all worked fine, so I didn't go the extra step to convert them to a .COM before using them. So I will convert this to a .COM and try again. Maybe that is the problem, why none of the programs I have attempted with disk access have worked.
  8. #28
    Converted to a .COM and it works ! That was an interesting lesson to learn.
  9. #29
    Aug 2006
    Chicagoland, Illinois, USA
    6,716
    I think your .exe didn't work because you may have been making assumptions in the code about what the default segment registers were set to. In a .COM, CS=DS=ES=SS, so missing something is much more likely to work by accident.
    Offering a bounty for:
    - A working Sanyo MBC-775 or Logabax 1600
  10. #30
    34,970
    18
    In the .EXE version, you have DS=SS=ES = PSP segment, but CS will be 10h beyond that (100h locations), so the command tail isn't accessible through CS. If you're still thinking about single-segment execution as an EXE, then you need to move the file name from the PSP into your own local working storage. Other than CS and SP (if a stack segment is declared), you're expected to load your segment registers appropriately.
    e.g.
        mov     ax,seg Data       ; my data segment
        mov     ds,ax
    The usual practice for a "small" .EXE program is to declare a separate segment for data and put all of your working storage there. Eliminates all of those nasty segment override prefixes. In fact, there are .COM programs that do this as well. Very useful when you're coding something that involves more that 64KiB of code or data.
