Results 1 to 10 of 11
Thread: IBM Eduquest Forty Sound Blaster Emulation
    Sep 2016
    Shrewsbury, MA
    1,331
    Default IBM Eduquest Forty Sound Blaster Emulation
    Just got my Eduquest upgraded with extra ram and a 100mhz Kingston Turbochip and I was looking to play some games on it. I was wondering if anyone knew if the original MWave card is able to do Sound Blaster emulation. My goal is to use it as a standalone unit, without any external speakers or peripherals if at all possible. Or if it can't do Sound Blaster emulation, maybe there is a way I can use a Sound Blaster and loop the output back in through the MWave card to get the sound out of the internal speaker.
    6,078
    44
    Could you please explain to us why on earth you would want to use an Mwave card specifically?
    = Excellent space heater
    Sep 2016
    Shrewsbury, MA
    1,331
    Because it's the stock card that has special headers for driving the internal speaker. Normally I just throw them out but if I want any sound at all through the speaker it has to stay
    Sep 2016
    Shrewsbury, MA
    1,331
    I do have a Sound Blaster 32 that would do the job, but since I want to use the internal speaker, is there a way to set the MWave card just as a passthrough so I can loop the output of the Sound Blaster back into the input on the MWave?
    Sep 2008
    SE MI
    4,907
    6
    If it's the AWE 32 Blaster, it sound have inputs for the CD & speaker. Check the upper right hand corner.
    Sep 2016
    Shrewsbury, MA
    1,331
    The one I have is the CT3600, I'll have to see what kind of inputs it has, never really looked before
    6,699
    My recollection of the eduquest mwave's sound blaster emulation is that it is not very good and not very compatible.
    Sep 2016
    Shrewsbury, MA
    1,331
    Looks like my CT3600 doesn't have the header for the internal speaker. Does anyone happen to have an isa sound blaster that does have the header for an internal speaker?
    This is what the MWave card and the connectors look like inside the Eduquest.
    Sep 2016
    Shrewsbury, MA
    1,331
    I'm not sure Im going to be able to find a replacement, which is why I'm thinking the best option might be to install a Sound Blaster normally and loop the output back in through the MWave and have the MWave set essentially just as a passthrough
    The mwave worked fine under Windows 95 playing dos soundblaster games.
    And the midi I found more pleasant than normal
    The issue I had was that the system could crash in duke 3d when a lot of sounds and actions were going on
    So I guess why not test it out?
