Results 1 to 10 of 12
Thread: Monitor cable stock
    Jan 2005
    Principality of Xeon (NJ)
    1,359
    Default Monitor cable stock
    Am I likely to find a source of 5 conductor shielded n?gauge cable suitable for an Atari replacement monitor cable locally? I really don't want to spend twice the cost in shipping alone.
    32,543
    Why not just use a cheap VGA cable and lop the ends off?
    Jan 2005
    1,359
    The hdmi cable I'm staring at seems a suitable thickness. The 9" vga monitor cable is too thick. Anyway I may have 1 spare vga cable somewhere and it's not sacrificial.
    The local Ace hardware sells suitable cable here. Don't know what you have there.
    32,543
    My point was that a cheap VGA cable is probably best suited to the job. Very often, the RGB leads are mini-coax in addition to the entire cable having at least a foil shield. The bandwidth demanded of VGA exceeds that required to run a simple 80s monitor.
    Jan 2005
    1,359
    Ataris use 13 pin dins. Nearly every vga cable is nearly twice the needed thickness. And as I've said I only have 1. Maybe ACE. The one nearest me is shut. But there's anudda ~12 miles from here.
    32,543
    There are thin VGA cables--I'm looking at one now. I have no idea how common 13 pin DINs are nowadays. When I had a 520ST, I made my own with perfboard, pins and epoxy potting compound.
    Jan 2005
    1,359
    Found vga extensions on ebay cheap. Bought 3.
    You can buy 13 dins all day on ebay.
    32,543
    They were somewhat uncommon in 1986, along with the floppy and ACSI connectors.
    Jan 2005
    1,359
    I guess we've come a long way.
