Results 11 to 20 of 21
Thread: Pcw9512
    Apr 2018
    Los Angeles, CA
    706
    Well, a 3.25" drive probably would fit also.
    Yeah, without some special drive, you have to physically alter the case with the 'file' from that kit, which I wouldn't do at this stage since you're basically damaging the case to just let you use physical disks for a couple more years. It made sense back in the day, but not really anymore.
    found on internet from someone who added a 3 1/2:
    my amstrad with the gotek in Drive A, and the original in B:
    -- Brian
    Systems: Amstad PCW 8256, Apple IIe/II+/Mac+/Mac 512k, Atari 800/520STFM, Commodore 64/Amiga 3000/PET 4032/SX-64, IBM PS/1 2121-B82, Kaypro II, Osborne 1, Tandy 1000 SX, TI-99/4A, TRS-80 Model 4 GA
    May 2018
    Lancashire
    237
    lots to think about.
    Not sure it even works yet !
    What is the startup I would expect without a disk ? Just gives a white screen at the moment and the drive light comes on.
    Jun 2013
    Montevideo, Uruguay
    386
    I have the same dilemma, and cutting the case seems hard just use a long floppy cable you can get it in the space between the case and the printer connector, and use it as an external drive.
    Also i done another mod i have an extra motherboard an installed into a case and do a small circuit for composite output will take less space.
    JonB sells an ide kit that is awsome for cp/m
    Apr 2018
    Los Angeles, CA
    706
    Quote Originally Posted by Gary C View Post
    You basically get nothing, just a fully bright screen. it doesn't do anything at all without a disk, which was confusing to me as well.
    -- Brian
  5. #15
    32,231
    18
    Not so confusing if you consider that, IIRC, the small bootstrap is actually part of the printer controller IC. You won't find any EPROMs on that thing. Text is constructed by software, so it can't even display a message before booting a working system.
  6. #16
    May 2018
    Lancashire
    237
    Oh, I read that info. It certainly was built to meet a very specific brief.
  7. #17
    32,231
    18
    That's what prompted me to get rid of my PCW. You can't even plug a garden-variety parallel or serial printer into it without a special adapter. The big attraction for me was the 512KB memory capacity and the pure graphics interface.
    My own PCW was a 120V model sold by Sears in the USA. But it's pretty clear that it was intended solely as a word processor and its rarity on this side of the Atlantic caused me to lose interest.
  8. #18
    Nov 2017
    UK, South East
    310
    I can send you a 9512 CP/M boot disk when you have sorted the drive belt out. PM me your details and I'll get one in the post.
    In addition to getting a 3" drive working, you can quite easily fit a Gotek drive to make life a little easier.
  9. #19
    May 2018
    Lancashire
    237
    Quote Originally Posted by zippysticks View Post
    Just got the lid off. That drive is really buried in there isn't it !
  10. #20
    Apr 2018
    Los Angeles, CA
    706
    Yeah, I actually had completely disassembled mine at one point so I could clean the case and insides and remove the second bay cover and it was quite a pain.. Lots of parts and everything was really packed in there. Tiny hands help.
    -- Brian
