Results 1 to 4 of 4
Thread: Tandy + PC compatibility
    Default Tandy + PC compatibility
    Hi All,
    How far does the Tandy compatibility goes with early PCs (386/486) as far as floppy drives go.
    Wikipedia for Tandy 1000 says that "All Tandy 1000 computers featured ... an IBM-standard floppy-disk controller supporting two drives"
    Does that mean that a 5.25" 1.2MB drive can work in either a 486 or Tandy 1000, which was designed to take a 1.2MB 5.25" floppy drive?
    The majority of 1000s wont support 1.2MB as they are high density.
    You might want to check out the faq for more details. http://www.oldskool.org/guides/tvdog/1kfaq.html
    Tandy followed the original Shugart floppy controller standard, not IBM's modification of it (which later became the generic PC clone standard). For example, rather than using a twist in the cable and setting both drives to DS1, the cable is straight through and the A: drive is set to DS0.
    Super .. thank you both, that is very good info.
