Results 1 to 7 of 7
Thread: Are there any apps that let you use your cell phone as a modem?
    Dec 2008
    United States of America
    88
    Default Are there any apps that let you use your cell phone as a modem?
    In conjunction with a usb to serial adapter?
    Maybe you could use an acoustic coupler with one of these?
    Many years ago i used an old mobile / cell phone as a modem, It was dog slow but it worked, IIRC i had to change a setting in the phones setup and my computer recognised it as a modem, It was connected via USB though.
    Dec 2008
    88
    That seems to depend on the quality of the handset. I've seen it work, but mine is sketchy.
    Quote Originally Posted by Moogle! View Post
    Certainly. But do any phones that run PalmOS (HP WebOS) work on any modern cell networks?
    5,749
    44
    The last phone I owned and could use as a modem (via serial or PCMCIA up to 9600bps) was a Motorola Timeport that I had to retire when CDMA was shutdown in 2014.
    I have not seen a smartphone that could operate as a serial terminal with a USB dongle in years. I've never seen anything remotely close to an app that bridged 3G/LTE/whatever data into an emulated modem. The closest was a smartphone running in hotspot mode and a Wifi-232.
    = Excellent space heater
    Mar 2011
    Atlanta, GA, USA
    1,477
    There are several projects (including some by forum members) that add an ESP8266 to a D-sub connector to create a modem emulator over WiFi. You could pair that with a hotspot running on your phone. All add functionality to the ESP8266 to speak Hayes AT command set. Some use a dialed number to IPort alias table. Some allow you to ATDT<ip>:<port> directly.
