Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Memory managers not working
  1. #21
    Jan 2010
    New Zealand
    4,167
    4
    Ramboost acts like memmaker. Ramsetup allow you tpo tweek the config. qconfig shows type of mem available, types of drive in the system and how they are setup. Chapter 10 of the User Guide which you may find as pdf online.
    Thomas Byers (DRI)- "You'll have a million people using the A> [MS-DOS prompt] forever. You'll have five million using [nongraphic] menu systems such as Topview, Concurrent PC-DOS, Desq, and those types. But there'll be 50 to 100 million using the iconic-based interfaces."
  2. #22
    Sep 2016
    Shrewsbury, MA
    1,335
    Qconfig shows about 19mb extended ram and says that 0kb is free. So I should go into ramsetup to try and reallocate that?
  3. #23
    Jan 2010
    New Zealand
    4,167
    4
    Run ramboost. I found the PC Dos User Guide and Chapter 13 will tell you what to do. It's all about memory configuration. https://archive.org/details/pc-dos-7.0/page/n7
    This page explains the differences between MS Dos and PC Dos memory management http://www.telecommander.com/pics/li...PCDOSV.6.3.htm
  4. #24
    Sep 2016
    Shrewsbury, MA
    1,335
    Quote Originally Posted by Caluser2000 View Post
    Thanks, I'll definitely take a look at that in the morning. I did go into ramsetup and am I right in thinking that all the upper memory is allocated for rom based on this table? The table isn't making much sense to me because it's showing there is available memory when dos is saying there is none.
  5. #25
    Jan 2010
    New Zealand
    4,167
    4
    Just for fun put in your config.sys file a new line after himem.sys dos=high,umb restart and see if there is a difference in conventional memory.
  6. #26
    Jan 2017
    Galicia, Spain
    194
    You can try the following changes:
    CONFIG.SYS
    Change NOEMS for RAM in the line that loads EMM386
    Change the line: DOS=HIGH to DOS=HIGH,UMB
    Comment out the line that loads IFSHLP.SYS
    Change DEVICE for DEVICEHIGH in the line that loads atapicd.sys (it's a CDROM driver, if you don't use one comment it)
    AUTOEXEC.BAT
    Put LH in front of the line that loads SMARTDRV.EXE
    Comment out the line that loads SHARE.EXE
    If you don't use the CDROM comment out the line that load MSCDEX too
    Hope this helps
  7. #27
    Sep 2016
    Shrewsbury, MA
    1,335
    Those autoexec and config changes did change it, now 16k of smartdrv, atapicd, and about 224 bytes of SVaudio is loaded into high memory according to mem /c. So now I have 534k free, but it still doesn't seem to be enough. I have no idea why some programs are loading into high memory and others aren't
  8. #28
    I think it was the UMB addition that made the high memory available, finally.
    Take this :
    and change the RAM back to NOEMS and see if that helps. It should free up more upper memory.
  9. #29
    Sep 2016
    Shrewsbury, MA
    1,335
    Take this :
    Just tried that and it freed up a couple kilobytes, but not much. It was enough to get over the threshold for the Creative install program though. The drivers are installed now, the last thing I have to figure out on this machine is how to get the original mwave card to play its line in continuously so I can loop the line out of the Creative card back in and have Sound Blaster sound
  10. #30
    Aug 2006
    Chicagoland, Illinois, USA
    6,706
    PC-DOS 6.3 doesn't have great memory management. (PC-DOS 7.0 isn't better; it comes with RAMBOOST which is very buggy.) Your best bet is to install QEMM 7 or later and then run QEMM's OPTIMIZE program, which usually never fails.
    Also, don't load SHARE any more, you don't need it.
    Offering a bounty for:
    - A working Sanyo MBC-775 or Logabax 1600
