Page 8 of 8 FirstFirst ... 45678
Results 71 to 77 of 77
Thread: New to me Rainbow 100A and VR201
  1. #71
    May 2018
    190
    Quote Originally Posted by tradde View Post
    Don't believe the Kermit I used supports other modes. I will have to look. I also need to check the original file to see if
    it too is truncated.
    OK I've learnt something hear. For me Kermit is just a file another transfer protocol in the manner of XMODEM, YMODEM and ZMODEM than you can select in your terminal program for a file transfer.
    I didn't realise it was an executable. Great work - you overcame a lot of hurdles.
  2. #72
    Quote Originally Posted by exidyboy View Post
    I too never had heard of a Kermit transfer protocol. I've use the program Kermit many times in the
    past but never had noticed that protocol selection. Maybe the Kermits I used didn't have it.
    Who knows. Now to figure out where to post this file so it can be used?
  3. #73
    The reason Kermit was created to start with was to allow transfer of files between different type of machines. As such, of course it is a protocol. But just as much you also needed an implementation, so of course it was also a program, with many different implementations for different machines.
  4. #74
    Default Rainbow 100A ROM dump
    Hopefully this works. Here is the file I created and transferred to my Mac.
    dec.zip
  5. #75
    Thank you very much!
    I'll see what they do in emulation
    Robert
  6. #76
    This was most timely.
    I have checked the file, and when split as 2000h, 2000h and the rest, it matches my eprom files here http://www.vcfed.org/forum/showthrea...0-CRC-ERROR-18
    I have now confirmed my issue isn't eprom related, so can move on to other things.
    Mark.
  7. #77
    You have nailed it.
    I can confirm that the file, once split at 2000h, 2000h and then the last portion, is a valid dump of all three roms when compared to my 100A.
    Your file helped me eliminate a bad rom, so thanks for your efforts.
    Mark.
