Results 1 to 10 of 10
Thread: mTCP and PC DOS 6.3 in VirtualBox
    Nov 2009
    Dublin, Ireland
    833
    Default mTCP and PC DOS 6.3 in VirtualBox
    mTCP and PC DOS 6.3 in VirtualBox.
    Managed to find a packet driver for the PCnet fast iii virtual card.
    Have gotten the time function to run.
    EDIT. IRCjr running now.
    It's all documented in the PDF file. (http://www.brutman.com/mTCP/mTCP_2015-07-05.pdf - page 22, including a link to the packet driver.)
    Nov 2009
    Dublin, Ireland
    833
    Ah yes as a British army warrant officer used to say t me When all else fails read your instructions
    Nov 2009
    Dublin, Ireland
    833
    Hi Mr Brutman,
    Got most of the EXEs to work.
    Thanks for the help.
    Francis
    New Zealand
    4,072
    4
    I hope we'll be seeing you more often over at #vc
    Nov 2009
    Dublin, Ireland
    833
    My wife is between chemo and radical surgery so I don't know if I will for awhile. Been geeking as a distraction while waiting for a date for the surgery.
    Got most apps working with DOS in VirtualBox. Stuck on the FTP server. keep getting Econn? error message.
    Nov 2009
    Dublin, Ireland
    833
    Finally got FTP server working with File zilla on Widodows 10.
    Nov 2009
    Dublin, Ireland
    833
    Logged into the FTP Server on my PS/1 from WfW in VirtualBox. No luck with DOS so far.
    Nov 2009
    Dublin, Ireland
    833
    Have set up Arachne in virtual dos. Tis working.
    EDIT: It's faster than Edge on Windows 10.
    Good work!
    Btw, in respect to VM performance..
    In Virtualbox, there's a CPU tab where you can limit the CPU usage for your DOS VM.
    Without some tools, like DOSidle (DOS) or WQGHLT (Win 3.x Enhanced Mode), CPU usage for each VM will always be at the max.
    Also, in some virtualizers, such as Virtual PC, running DOS in V86 mode (EMM386 loaded) might be faster than in real-mode.
    I suspect that real-mode compatibility in these virtualizers requires some emulation, thus slowing down the DOS VM.
    Activated hardware virtualization (AMD-V,Intel-VT etc.) assists the virtualizers, thus they can handle real-mode quicker.
    Anyway, these are just my two cents.
    Good luck and best wishes,
    Jo22
    "Time, it seems, doesn't flow. For some it's fast, for some it's slow.
    In what to one race is no time at all, another race can rise and fall..." -The Minstrel
