Page 1 of 11 12345 ... LastLast
Results 1 to 10 of 101
Thread: PET 3032 garbage screen problem
    Default PET 3032 garbage screen problem
    Hi
    My pet 3032 has the problem of garbage screen
    I have checked all pcb voltages and they are correct. + 5V, + 12V, -5V and + 9V, according to the diagrams:
    http://www.zimmers.net/anonftp/pub/c...N/320349-1.gif
    to
    http://www.zimmers.net/anonftp/pub/c...N/320349-8.gif
    I have checked the ram and roms with the http://blog.tynemouthsoftware.co.uk/...nt-boards.html and they are ok.
    When boot with replacement boards the same
    The difference is that if I press the reset button on the replacement board it loads the basic screen but with garbage, whether I use the board roms/rams or replaced roms/rams
    Help me please
    If RAM and ROMs are ok (but I doubt they can be safely tested from a daughterboard, having made my own daughterboard too), then this looks like a data (or even address/decode) conflict with some other parts. It could be an I/O chip or maybe a data bus transceiver (74LS244) or it might be an address bus buffer failing or any part of address decoding logic faiiling. Do you have an oscilloscope or logic probe?
    Frank IZ8DWF
    Yes, I have an osilloscope. What should i check? What chips? What pins? What values?
    Feb 2009
    Southern California, USA
    3,049
    Quote Originally Posted by Fran View Post
    I agree with Frank that because of the alternating inverse video, and repeating patterns, etc. there may be an addressing logic issue rather than bad RAM. Can someone post the info about making a simple NOP Generator so that the address lines can be easily traced?
    Dec 2005
    Toronto ON Canada
    7,363
    Here's the wiring; use a 40-pin socket, bend out the appropriate pins and run the wires around the outside so you can insert the 6502.
    An interesting blog, although the link to the instructions seems to be dead:
    http://www.8bit-homecomputermuseum.a...t/bluepet.html
    Feb 2009
    3,049
    Yes, that's it. The trick is to use two sockets so that the NOP instruction pattern (1110 1010) is connected to the CPU chip only on the top socket, and the data lines (D7 thru D0) pins 26 thru 33 are open to the board circuitry on the bottom socket. In that way the CPU will happily execute NOPs all day while incrementing the address lines from $0000 to $FFFF. The CPU will then roll over to zero and start again. With a scope you can follow the square waves on the address lines. A0 will have the highest frequency of about 500 KHZ, A1 half of that, and A2 half of A1. If you spot something not in that pattern, you have found the problem. Note however that the RAM address inputs are multiplexed with the dynamic RAM refresh logic so it gets a little messy there. Hopefully with this method you will spot a bad buffer or whatever.
    Also I would look at the eight data lines at the board for shorted or open signals. Note that the $E900-EFFF space is not allocated and there will be tri-state there where no device is selected. You can use SEL E to help sync that period and ignore.
    With a nop generator under the 6502, I'd first check each address going through UC3 and UB3:
    Input and output from the buffers must be the same for all addresses. Since the garbage pattern is exactly 16 bytes wide, I'd pay special attention to A4 (AB4 on that schematic) and its path.
    A4 path to the RAMs goes through UE5, that's the second place to look for problems:
    http://www.zimmers.net/anonftp/pub/c...N/320349-5.gif
    Finally, should it be only a video RAM issue (I don't believe so however), there's UF5 that passes BA4 to them:
    http://www.zimmers.net/anonftp/pub/c...N/320349-7.gif
    HTH
    Frank IZ8DWF
    May 2018
    Lancashire
    703
    19
    Ive had some luck with https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
    Just used it to resolve a problem with my Apple II as the ram was not being written to sucessfully, was quite satisfying to trace the logic visually.
    It turned out I had used the wrong PC ATX supply and didnt have a -5V !
    Dec 2005
    Toronto ON Canada
    7,363
    Not sure why you need two sockets; bending out the pins disconnects the data lines from the board although you might want to put a piece of paper under the socket to avoid inadvertent contact with the bent pins.
