Page 3 of 11 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 101
Thread: PET 3032 garbage screen problem
  1. #21
    Not sure what you mean; the relevant pins of the socket are bent out and up and connected appropriately (with a piece of paper underneath to prevent the bent out pins from touching the system socket), and the 6502 is just normally inserted into the socket.
    But sure, if you have two sockets that works as well and no piece of paper needed.
    If I could find mine I'd post a picture
    It wasn't clear which pins you were bending. Maybe if I'd looked at the picture better I'd have understood. Still making the power connections would be easier with a second socket.
  2. #22
  3. #23
    ... With a scope you can follow the square waves on the address lines. A0 will have the highest frequency of about 500 KHZ, A1 half of that, and A2 half of A1. If you spot something not in that pattern, you have found the problem.
    These are the values with the scope
  4. #24
    Feb 2009
    Southern California, USA
    2,741
    Guys,
    On looking at the videos of the PET screen, there is a lot of hash. Could there be a fault on the Screen Address bus? Bad multiplexer at F6, F5 or F3 (LS157) or noise on CLK1 which selects between display refresh and CPU address?
    -Dave
  5. #25
    Feb 2009
    2,741
    Quote Originally Posted by Fran View Post
    Looks OK. Good work!
  6. #26
    Hi
    Today I replaced the 6502 and the pet works, the prompt appears, but with garbage, the keyboard works as you can see in the video.
    the original 6502 is faulty
  7. #27
    Either the addressing from the CPU side or the addressing from the video side is not working correctly.
  8. #28
    Hi
    sorry, this is not correct, I have plugged and unplugged the original 6502 several times and it works, with garbage and keyboard.
  9. #29
    Feb 2009
    2,741
    Fran,
    Did you check the signals from the chips mentioned in message #24 using the NOP Generator?
  10. #30
    Yes dave_m
    Input values F3-F5-F6:
    What other signals/values must be checked on F3-F5 and F6?
    I have doubts if the C3 waves are correct, the output waveforms must be the same as the input waveforms? The output waveforms in B3 are very similar to the input waveforms
    AB0 OUT 6502
    C3 input wabe it is the same
    C3 out
