Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Borland QPRO V 3.0 .WQ1 files - how to transfer?
    32,222
    No, but I knew Dash Chang back in the day and used Microplan a bit on x80. I probably have a copy here somewhere.
    Wonder if that fancy Github toolkit can handle Multiplan files...
    Mar 2013
    Chaffee, MO
    1,201
    It says it handles DOS Multiplan files, but nothing about CP/M Multiplan files.
    Recognized formats:
    Microsoft Works files:
    Word Processing v1-v2000: retrieve almost all content (except some pictures and some DOS's character encoding),
    Word Processing v5-8: retrieve almost all content,
    Spreadsheet v1-v2000: may retrieve cell's content with cell's format
    Database v1-v2000: may retrieve the main database's content but not the filters, frames, reports, ...
    Microsoft Write files: retrieve all content
    Microsoft Word for DOS files: retrieves all content. Style information, page numbers, line numbers are not recovered.
    Lotus Wk1-Wk4 and 123 files: retrieve cell's content with cell's format and some graphics.
    Microsoft Multiplan DOS v1-v3 files: retrieve cell's content.
    Quattro Pro Wq1-Wq2, Wb1-Wb3 files: retrieve cell's content with cell's format and some graphics.
    Quattro Pro qpw (v9) files: retrieve cell's content with cell's format and some graphics. This filter probably also works for some newest version of qwp files.
    For the CP/M Version it's easy to use the Transfer Option of Normal to read in *.MP files.
    Once a file is read in, change the Transfer Option to Symbolic.
    Then use Transfer Save to write out a File01.SLK
    Excel will read a .SLK file and create an .XLS
    Then Clear Multiplan with Transfer Clear.
    Repeat for the next 1xx files.
    Larry
    3,253
    That's Chang Labs MicroPlan spreadsheet, rather than Microsoft Multiplan. Just FYI.
