Results 1 to 5 of 5
Thread: Osborne 1: Adapting for conventional Shugart with a TM-100-1?
    Oct 2016
    Illinois, USA
    420
    Default Osborne 1: Adapting for conventional Shugart with a TM-100-1?
    So, my B: drive's suddenly stopped being able to actuate the head carriage at all in a way that seems to indicate a fault with a discrete component on the drive. While I haven't given up on it yet, I've had hacking together a crude adapter for a conventional shugart drive in mind if need calls for it as a last resort option - It looks like someone's already done the groundwork here, but they had Gotek use in mind. For a real FDD, It'd just be a matter of splicing a molex connector into the voltage out lines in lieu of just leaving them disconnected, wouldn't it?
    Oct 2016
    Illinois, USA
    420
    ADDENDUM: Schematics for Osborne's custom logic board can be found here, p. 105 (129 by PDF numbering).
    32,489
    18
    Basically, you cut the wires going to pins 11,13,15,17 and connect them to the +12 side of a 4-pin molex power connector and pins 21,23,25 and connect them to the +5 side. Get your ground from any of the other odd-numbered pins.
    If that's what you're planning, it'll work.
    Oct 2016
    Illinois, USA
    420
    Yup! That's what I had in mind.
    As far as the current drive goes, tentative logic probing implicates a MC14023B on the offending board. Got a part order in and am hoping for the best...
    Oct 2016
    Illinois, USA
    420
    Unfortunately, it wasn't the MC14023. The plot's also thickened. (Oh, I hate it when it does that.)
    When I swapped the two drives' controller boards after realizing the 14023 swap didn't fix the bad drive's issues, neither Controller A (my known good drive's controller) in Drive B nor Controller B (the board with the 14023 i just replaced) in Drive A worked. The A/B pair exhibited the same symptoms normally seen in the B/B pair, while the B/A pair just kept "jittering" the head back and forth repeatedly. Clearly, B: has both mechanical and logic board-related issues...It's been one of those days.
    So, once I've got my PC 5150 and XT's drive issues sorted out I think I will consider swapping in my spare TM-100-1A with a hacked up cable adapter. Non-connect some pins, patch out the +5V, +12VDC, and two ground wires into a molex connection...Dead simple. Hopefully. Weirdly, CMI and Tandon used the same bezel design so the faceplate shouldn't cause any issues here.
