Thread: 54-15422-01 Panel Cab Kit for KDF11-B
    Default 54-15422-01 Panel Cab Kit for KDF11-B
    I am looking for the cable as pictured that goes between the Cab Kit Panel and the KDF11-B. Would also like documentation on the cab kit, can't seem to find it or the designation of the cable. Thank you for any help.
    Cheers,
    LSI11AL
    Dec 2010
    Seattle, WA
    1,837
    Did you buy one of these on eBay and now you have the console panel but not the cable?
    www.ebay.com/itm/DEC-DIGITAL-VINTAGE-54-15422-01-PANEL-/312613107570
    www.ebay.com/itm/DEC-DIGITAL-VINTAGE-54-15422-01-PANEL-/312709614900
    I should have bought one of those for my M8189 KDF11-B 11/23+
    If I had one of those panels but not the cable I would just make my own cable. It's just a 20-conductor ribbon cable with a 20-pin IDC connector on one end and split in half to two 10-pin IDC connectors on the other end. I might have all or most of the parts on hand plus an IDC connector press.
    Yes, I did buy one of those off of ebay. Since I do not have cable, connectors or IDC connector press I was hoping to find a premade cable. Otherwise I would have to buy multiple connectors, cable and the press probably from different vendors and separate shipping charges. By the time I got through a single made up cable including shipping would hopefully come out to less!!
    Dec 2010
    Seattle, WA
    1,837
    I have a full 100 foot spool of 3M 3302/20 multicolor ribbon cable on hand. That's the expensive part, $93 at Mouser new if you bought it there, or $45 for the solid gray 3365/20 ribbon cable.
    If I was going to make a single cable myself I might pay full price for new brand name 3M connectors. I'm not sure what connectors DEC used, they are a slightly different style.
    3421-7600 20-pin IDC
    3448-3020 20-pin IDC strain relief (optional)
    3490-2 20-pin IDC pull tab (optional)
    (2x) 3473-7600 10-pin IDC
    (2x) 3448-3010 10-pin IDC strain relief (optional)
    (2x) 3490-1 10-pin IDC pull tab (optional)
    That's $14 for all of those parts at Mouser, plus $8 for shipping if I didn't order anything else at the same time to spread the shipping cost over more parts. If I could find an original DEC cable for the M8189 KDF11-B 11/23+ console panel somewhere it's likely it would cost more than $22 with shipping.
    If you give up trying to find an original DEC cable I would be willing to consider building one for the cost of the new connector parts and shipping. I have a 3M Scotchflex 3640 press and locator plate for IDC connectors, which makes it easy to press the connectors onto the ribbon cable. Before I got that I destroyed a few connectors trying to press them onto ribbon cable without the proper tools.
    Thanks for the offer!! I will wait a week or so and see if anything turns up and if not I will be back in touch.
    Cheers!
