Results 1 to 10 of 26
Thread: 286 PC keeps killing I/O cards (exploding caps)
    Default 286 PC keeps killing I/O cards (exploding caps)
    I have a 286 that came with 2 bad caps close to the PSU (2 10mF 16V caps that needed replacing. One was completely blown and another damaged. One was short circuit and the other open circuit).
    I replaced those 2 caps and the machine booted fine .....
    But when I inserted an I/O card in an ISA slot, I noticed that the PC did not start (not even the PSU fan would start).
    When I removed the I/O card the PC would boot fine again.
    So I started poking around the I/O card and noticed a capacitor that was short circuit. This capacitor was hooked up to the -12V rail, and caused the -12V to short to GND. Not good.
    I wanted to verify my claims that this was causing the PC not to start, so I inserted the I/O card back in the PC and started the PC. Only this time the capacitor exploded on my I/O card , and the PC was starting. (I guess the explosion of the cap removed the short).
    Now, I inserted a different type of I/O card in the PC (an IBM serial / parallel card), thinking the previous issue was caused by the I/O card and not the computer but guess what .... again a capacitor blew, this time on the IBM card. I believe the cap that exploded is again linked to the -12V rail.
    Now, I don't really feel like blowing up any more cards (thank god its bedtime), but I wanted to check with you guys if you think I just had bad luck with 2 I/O cards that had bad caps. Or if something else is at play (perhaps the PC is causing all of this).
    Any tips on how to further diagnose this ?
    The PC is booting now with the cards, and the AMI bios boot screen seems to detect the serial / parallel ports on it, although I tried to setup an LPT interlnk/intersvr session and that failed (perhaps related to the blown cap).
    Thx
    Retro enthousiast. Love everything < 486. Learning and sharing on my little channel
  2. Default
    Is the -12V rail actually -12 volts?
    3,253
    Were all of these cards from the same computer originally? If so, then they would have the same amount of use/wear/aging and having multiple capacitors blow on different parts would not be too surprising.
    Sounds like two bad I/O cards to me.
    FWIW, I have several of those IBM serial / parallel cards with shorted caps on them.
    tantalum caps explode, it's what they do
    Here are the exploded caps in question (the blue ones and the orange / red ones) :
    I assume both are 10 microfarad 16V tantalum caps and can be replaced by this : https://benl.rs-online.com/web/p/tan...itors/5382133/ ?
    I already replaced these 3-legged ones by 2-legged ones on my IBMS as per excellent instructions on minuszerodegrees.net
    It is not uncommon for those Tant caps to short out however, it does seem like a coincidence the experience you have had.These caps are very sensitive to over voltage, much more so than an electrolytic cap. So you should check that the -12v rail is that and not any higher.
    Unfortunately when they "Explode" they can sometimes take out something else on the card, I have 2 IBM CGA cards here, Both worked perfectly until one day a tant C8 exploded, I replaced the tants but one card is dead as a door nail and the other shows garbage on the monitor, I also have a couple of IBM serial / parallel cards which have shorted tants, Haven't looked at any of them in a while, They got put away for another day which never seem's to arrive.
    Quote Originally Posted by Malc View Post
    Same here. But before I put them away I removed the shorted ones from the circuit and the cards worked without them. But they're still waiting for replacement tants.
    Will check that ... thx.... old PSU so you never know....
