Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Is DB19 not a manufactured format?
    Actually if not all the pins are used in the 19, perhaps you could adapt to a 15, which still seems to be pretty common.
    The Lower Planes BBS Ports 22/23 telnet or SSH
    Pineapple Home of the Hardware Database
    Australian BBS list old style BBS registry listing.
    But 23 position D-subs are more common that 19-position ones. Why bother hacking a DB25?
    The last time I needed one, I would have had to either order 1000 of them, or pay an obscene amount for one. How common is a DB25?
    34,128
    18
    Less common, it seems, that it used to be.
    I've discarded enough 25-pin male to female cables to displace all the DSDD floppies in that other thread.
  5. #15
    Dec 2012
    Colorado
    214
    Looking at Digikey and Mouser, the 19 pin D-sub connectors are still made, but you probably won't like the prices for any of the ones with shorter lead time availability. Some are marked as ship from manufacturer stock. So if you find them for less than $50 each (or higher), consider yourself lucky. Are you aware of this? https://www.bigmessowires.com/shop/p...tension-cable/
  6. #16
    Jan 2012
    Connecticut, USA
    2,721
    Quote Originally Posted by cruff View Post
    yeah its a bit pricey
  7. #17
    May 2018
    Lancashire
    388
    5
  8. #18
    34,128
    18
    Care to point me at the Mouser or Digikey entries? I found one for Mouser, but it's apparently a typo for a 15 pin one.
  9. #19
    Dec 2012
    Colorado
    214
