Results 1 to 3 of 3
Thread: savem in Xroar CoCo emulator
    Hamilton, Ontario, Canada
    3,788
    Default savem in Xroar CoCo emulator
    Ok, here is the latest information I'm looking for;
    I'm running Xroar 35.2 and I'm loading a .dsk that contains a .bin file. I load that .bin into memory and, if I exec it, it runs fine.
    Can I do a savem of that .bin file and, if so, how do I determine the start, end and execute addresses for it?
    I want to burn the .bin file to an EPROM, so I'm guessing that the execution address will be $C000, but how to find the other 2 addresses escapes me.
    Help would be appreciated.
    Legacy Computers and Parts
    Its been awhile, since I done what you are doing(about 25years),
    There are some Peek commands that will alow you to see the start,end and exec of a BIN file. I though I had them wrote down but must of lost that page.
    But did find the cassette peek commands to do that with cassette BIN files, just need to get the correct address for the disk.
    Here's the cassette ones:
    Start address: PEEK(487)*256+PEEK(488 ) again this is for cassette BIN
    End address: PEEK(126)*256+PEEK(127)
    Exec address: PEEK(156)*256+PEEK(157)
    The disk files will be the same format but with different address. Hope this info helps.
    My collection is: few Coco2's , a few Tandy 1000TL, TL2, RLX and assorted old cards and motherboards
    3,788
    Thanks Ec1564,
    That's a start. That would give me a .ccc file, right?
    It may be enough to do it if someone can't come up from the disk ones.
    When I save it out, I can specify the exec address that I want it to start at?
    OK, I have been informed that I wouldn't be able to run this as a ROM, so, it's been extracted from the .dsk and I'll have to run it as a disk file.
    Thank you for the idea though.
