Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Announcing another TRS-80 Software project: Scott19!
    Default Announcing another TRS-80 Software project: Scott19!
    Scott Adams game interpeter ported to the TRS-80.
    https://github.com/voidware/scott19
  2. Default
    A great loader but it appears to lack disk save/load functionality or perhaps I have missed something? Are there any plans to develop this loader further to incorporate this?
    Kind regards
    John
    Hi!
    Sorry, yes you noticed the missing save/load game. oops!
    I do plan to implement this. Some of the code is there already, it "saves" into a buffer so that you can restart, but i just need to add code to actually save to disk and load from disk to make the save/load work. Some of those bits are TRS-80 specific, but if i run into problems, there are a lot of knowlegeable people on this forum that hopefully help explain the disk IO stuff.
    I'm playing with the MC10 version. My as1 didn't like the assembly, so I tried asl (some modification to asm) but I'm not sure what I need to do with tapeify. I'll give as1 another try.
    what is the mc10? I've tested this on TRS-80 model 1, 3, 4 in emulator and on a real 4p.
    I think anything else, i'm going to need some help!
    Quote Originally Posted by steaminghacker View Post
    The MC10 is the Tandy (TRS80) Micro Color 10 Computer (based on the Motorola 6803). I've got it to assemble and I think I have it to tape image (.c10). I've found a few errors in the 6801 code. I've also played with the C (ncurses) code and it works. I'll post my changes to my fork and we can work on getting it all merged later. I don't have any TRS-80s other that he CoCos and MC10s. My only Z80 are Steve Ciarcia's boards (well z180).
    Cool! I have aland.c10 running on the MC10 Javascript emulator. The file is roughly 13K in size.
    I'm more than happy to include changes for the MC10 in the sourcecode. Is there a MC10 emulator?
  9. #9
    Browser based MC10 (Javascript):
    http://mc-10.com/
    My changes are mostly specific to assembling with the asl ( A S L ) assembler. I couldn't find the as1 ( A S 1 ) assembler. The one I found didn't like the comments. So I doubt I have the correct as1 assembler.
    Let me clean things up a bit, clean up the assemble and C compile scripts and I'll share them on my github page.
    Thanks for sharing this.
  10. #10
    Just a quick update.
    I've added (somewhat primitive) save/load games;
    When you run, you're asked if you want to restore a previously saved game. Saying yes, trys to load "scott/sav:1" (sorry you can't enter a name yet).
    And when you "SAVE GAME", it will overwrite/create "scott/sav:1".
    Had a few problems getting this working. i'm definitely having a battle with DOS.
    If i leave interrupts disabled:
    * m4 works
    * save/load works
    * dos getline doesn't work => use my own
    if i enable interrups:
    * save/load works
    * getline works
    * m4 does't work.
    need more investigation!
    Currently interrups off.
