Results 1 to 6 of 6
Thread: Reset switch for PET 8032
    Apr 2011
    San Francisco, CA
    517
    Default Reset switch for PET 8032
    Hi all,
    I wanted to make a simple reset switch for my 8032, to spare wear and tear on the machine while I mess around with some software development.
    I know the J4 header has /RST on pin 22. Is it safe to just switch this pin to GND through a pushbutton? Or might there be a better/safer way to reset the 8032 externally?
    Thanks!
    4,032
    Yes that is OK - the switch is pulling down current through a 1kOhm resistor R15. The 7417 buffer (UD15 output pin 6) is open collector.
    Use a 100 Ohm resistor to GND if you prefer.
    If you are resetting the PET to do software development though (recover from a crash) - you may need to consider another avenue as the DRAM refresh may be interrupted during a reset? Just a thought...
    Nope, refresh only depends on two counters that are fed from the master clock generator. That's not affected by a CPU reset.
    Frank
    Dec 2005
    Toronto ON Canada
    7,361
    Note that if you hold the DIAGNOSTIC line low while resetting you will enter the monitor instead of doing a full reset. See:
    http://www.6502.org/users/andre/petindex/repairs.html
    There's also this thread:
    http://www.vcfed.org/forum/showthrea...set-Switch-Mod
    Feb 2009
    Southern California, USA
    3,012
    Quote Originally Posted by gubbish View Post
    Grounding pin 22 leads to a hard reset with all user memory cleared to $AA. Mike's links have a soft reset where user memory is not cleared for examination in the M/L Monitor. From the monitor (in BASIC 4) a Go command to FD16 ( .g fd16 ) will perform a hard reset.
    The pin opposite pin 22 on the connector is ground as are all the pins in that row.
    Apr 2011
    San Francisco, CA
    517
    Thanks very much, this is quite useful. I rigged up the hard reset switch to ground pin 22 through a 100 ohm resistor, which works well. May include the option to go to the monitor as well.
