Results 1 to 10 of 14
Thread: Wanted: old-style I/O shield with the slot cover tabs not broken off
    Default Wanted: old-style I/O shield with the slot cover tabs not broken off
    The Design:
    https://ibb.co/HpCb9WD
    I/O shields with only a few ports and breakable tabs like this are rare and found mainly with vintage 90's motherboards or new-in-box beige ATX cases.
    See those tab covers on the gameport and audio ports on this sample picture? I want one with the hole placement looking like this but has tab covers on all ports so I can peel them off for myself. I have a motherboard that I want to have a cleaner look by covering up the ports I won't use. At the very least I need the parallel port covered up on the I/O shield.
    I only need the following exposed, based this I/O shield design in the above photo:
    Two PS/2 ports
    Two USB ports
    Two serial ports
    This is what I want my I/O shield to look like, based on this description:
    https://ibb.co/2Pd23vf
    It does not have to be the breakable tab design, as long as it is an I/O shield that only allows the ones I want in the list. Needs to be metal too.
    Thanks guys.
    32,489
    At least one model of HP used a gray vinyl overlay to cover the punched-out holes. But I'll have a look at my collection.
    Lake Havasu City, Arizona USA
    283
    Something like this might be the best you can hope for because almost everything from that era had a dang Parallel Port poking out the back that required the port to be opened.
    32,489
    That's the problem--almost any vintage I/O shield will have a parallel port cutout on it. I think I've got one without, but it's in use currently. I've got one with punchout tabs, but it's not for the usual outline--it attaches with screws.
    Quote Originally Posted by Syclops View Post
    YOU ARE A GENIUS!!! Why didn't I think of that, I simply plug the LPT port...
    I have some of those covers myself. Please, please take a picture of the other side so I may replicate your design. Syclops, thank you so much! I'm so glad I asked.
    May I see a picture for reference please when you have a moment Chuck? Just the back of the PC will do...
    283
    There isn't really anything to it, but you have to use 2 of those covers and run the screws through both of them to hold it in place.
    I have a 286 case that has one serial and one parallel port hole covered with just an internal cover and an outside screw to secure it and another, a black case, that has three parallel holes and two serial holes with all the covers still in place.
    32,489
    The I/O shield isn't installed; I'll have to dig it out.
    I should have said two outside screws as there are two of them in the normal end notches of each port cover.
