Results 21 to 30 of 36
Thread: Designing a 16-bit ROM card
  1. #21
    When the system is doing 16-bit transfers: do odd addresses ever show up on the ISA bus, or is A0 always low?
  2. #22
    Mar 2011
    Atlanta, GA, USA
    1,497
    No. Word transfers have to be word aligned - otherwise the BIU or the chipset breaks them apart.
  3. #23
    clearly not finished, still needs: some bus labeling, decoupling caps, address assignment DIP switch, pull ups for the OC inverters, etc.
    but what's your opinion on the steering logic?
    isa16.pdf
  4. #24
    my main questions with the logic posted in the previous PDF are revolving around the use of SBHE#
    should I be qualifying my assertion of MEMCS16# with a SBHE# test, or just assert it on a matching address regardless and save 2 gates?
    should I be testing SBHE# in addition to A0 to determine whether an 8-bit read (of the upper byte) is occurring, or assume 8-bit whenever A0 is high and save 2 more gates?
  5. #25
    Mar 2011
    Atlanta, GA, USA
    1,497
    Sorry for the delay. I'm at VCF-MW and it's been a long day. Still trying to get my talk ready for tomorrow. I can try and look at this if I have time tomorrow or Sunday. Otherwise will be Tuesday before I'm back in town and things settle down.
  6. #26
    no problem at all, I appreciate any input - no rush
    I went ahead and finished the design, I think it's solid but another set of eyes certainly couldn't hurt
    isa16.zip
  7. #27
    would still love to get some input on this design before I route out the board and send it to production
  8. #28
    Mar 2011
    Atlanta, GA, USA
    1,497
    Sorry for the delay. Busy week. The logic seems to work:
                                   A0  SBHE#  D0-7    D8-15   U3D-8  U2B-4
    8-bit read from even address    0    1    Lower    D/C      1      0
    8-bit read from odd address     1    1    Upper    D/C      0      1
    16-bit read from even address   0    0    Lower   Upper     1      0
    Any write                      D/C  D/C   Hi-Z    Hi-Z      1      1
    The only issue I see is when the board is installed in an 8-bit slot, you'll want to have a pull-up on SBHE# to ensure it's state is deterministic.
  9. #29
    excellent, I really appreciate the review
    I'll toss a 30k pull up on SBHE#
  10. #30
