Thread: DEC VAX 4000-300 w/ R400X
    Default DEC VAX 4000-300 w/ R400X
    I saw this unit for sale and it looks like the R400X is a drive expansion chassis, is that correct? How does it connect to the VAX 4000, SCSI? What external drives would I be able to connect to it(Tape,Disk)?
    Thanks
    It would use DSSI and have DSSI enabled hard drives in them, typically RFxx series.
    http://www.bitsavers.org/pdf/dec/vax...tems_Dec90.pdf
    Collector of all things Digital.
    In collection: VAXserver 3100, VAXstation 3100, DECpc LPv+ 433dx, Rainbow 100B, and VAX 4000-100A. Plus over a hundred Digital items ranging from documents to coffee mugs.
    Feb 2011
    2,226
    10
    Quote Originally Posted by DECtechGuy View Post
    And DSSI Disks are getting rare and expensive...
    G4UGM
    What type of cable/card do you need to connect a B400x card expander to a VAX4000-300?
    Dec 2010
    Seattle, WA
    1,837
    Quote Originally Posted by maxfli View Post
    For the Q-Bus connection the expansion chassis should have an M9405-PA card and the CPU chassis should have an M9404-PA card. Each card has two 3-row 50-pin D-shell connectors. Two of the 50-pin cables are needed to connect the two cards together. The cable part might be a BC04V-09 (which should be a 9 foot long cable).
