Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: 5150 U33 BIOS with ‘82 version anomaly?
    Sep 2019
    Cambridge, MA
    19
    Default 5150 U33 BIOS with ‘82 version anomaly?
    So I took a dump of the U33 chip on my non-working 5150 that I found on the side of the road. This chip is an NEC D2364AC016. The hex dump showed “1501476 COPR. IBM 1982” in the first section, so I downloaded a copy of the 10/27/82 revision of BIOS (from minus zero) to compare it. It almost matches exactly, except a bit near the beginning, and a bit near the end.
    I can provide a copy of the file if anyone is interested. I don’t know if it’s a corrupt chip, something that went wrong while reading it, or a previously unknown version of BIOS. Who knows, maybe this is why the motherboard “appears” dead.
    May 2006
    Melbourne, Australia
    6,803
    Quote Originally Posted by FiveGHz View Post
    That's what I am putting my bet on.
    Man, what roads are you driving on? I'd love to start finding IBMs on the side of the road.
    Current favorites: IBM 5160 (EGA+Hercules+PGC, 8 floppy drives, XT-IDE), DCC D-116 (Nova 1200 clone), ASR 33 Teletype (now FULLY armed and operational! Mostly.)
    Wishlist: IBM 5161 (expansion chassis), Diablo 31/RK02/RK05 or equivalent, Data General Nova software, and the meaning of life.
    Sep 2019
    Cambridge, MA
    19
    Quote Originally Posted by modem7 View Post
    On closer inspection I was mistaken, the year reads “1981” and the rest of the hex matches the 1982 BIOS exactly except the last bit in the file is 77 vs. 78. It does not resemble either 1981 BIOS images at all.
    Sep 2019
    Cambridge, MA
    19
    Quote Originally Posted by Nevets01 View Post
    It was shear luck, probably a very rare occurrence.
    May 2006
    6,803
    Which suggests that the content is not corrupt/damaged (i.e. not the cause of your non-working 5150).
    Like the 'NEC D2364' on one my early 5160 motherboards, pictured in the top photo at [here].
    Note the seven-digit IBM part number ("5000027") that is printed on the chip.
    Does yours have a seven-digit IBM part number printed on it ?
    Sep 2019
    Cambridge, MA
    19
    It’s hard to tell. Here is a picture but the text is a bit worn off.
    Sep 2019
    Cambridge, MA
    19
    I looked at it again under macro lens with different light. Seems to be 1501476, which would match the 10/27/82 BIOS
  9. #9
    34,965
    18
    Popping the IR filter from a cheap webcam results in a good tool for reading faded IC printing.
  10. #10
    hmm I wonder if that works with NVGs too, I'll have to try it sometime
