Results 1 to 10 of 14
Thread: Make your DOS menu system
    Sep 2008
    SE MI
    4,124
    6
    Default Make your DOS menu system
    Below are all the ingredients for a simple, precious memory sipping, DOS menu program for the purist. Kudos to Van Wolverton.
    The following is a list of all the doc's, .com's, and .bat's that are required. These small programs are to be assembled in DOS using DEBUG. You will need to install ANSI.SYS in your CONFIG.SYS ([device=c:\dos\ansi.sys] for example) in order for the ASCII codes and menu overlay to function properly. Make a directory on your c:\ drive named 'MENU'. All of the files associated with the menu program should be located in the 'MENU' directory.
    1) ANSI_ESC.TXT - using the prompt $e[ function to add color
    2) MAINMENU.BAT - menu program
    3) BIGCURS.COM - turns the cursor into a block
    4) NOCURS.COM - turns the cursor off
    5) NORMCURS.COM - returns the cursor to its normal appearance
    6) REPLY.COM - holds the cursor in its place within the MAINMENU.BAT program
    7) MAINMENU.DOC - ASCII representation of the menu overlay
    REPLY.COM
    debug
    -a 100
    xxxx:0100 mov ah,8
    xxxx:0102 int 21
    xxxx:0104 cmp al,0
    xxxx:0106 jnz 10a
    xxxx:0108 int 21
    xxxx:010A mov ah,4c
    xxxx:010C int 21
    xxxx:010E
    -r cx
    CX 0000
    :e
    -n reply.com
    -w
    Writing 000E bytes
    -q
    BIGCURS.COM
    debug
    -a 100
    xxxx:0100 mov ah,1
    xxxx:0102 mov cx,10C
    xxxx:0105 int 10
    xxxx:0107 int 20
    xxxx:0109
    -r cx
    CX 0000
    :9
    -n bigcurs.com
    -w
    Writing 0009 bytes
    -q
    NORMCURS.COM
    debug
    -a 100
    xxxx:0100 mov ah,0f
    xxxx:0102 int 10
    xxxx:0104 cmp al,7
    xxxx:0106 jz 10d
    xxxx:0108 mov cx,607
    xxxx:010B jmp 110
    xxxx:010D mov cx,0b8c
    xxxx:0110 mov ah,1
    xxxx:0112 int 10
    xxxx:0114 int 20
    xxxx:0116
    -r cx
    CX 0000
    :16
    -n normcurs
    -w
    Writing 0016 bytes
    -q
    NOCURS.COM
     debug
    -a 100
    xxxx:0100 mov ah,1
    xxxx:0102 mov ch,20
    xxxx:0104 int 10
    xxxx:0106 int 20
    xxxx:0108
    -r cx
    CX 0000
    :8
    -n nocurs.com
    -w
    Writing 0008 bytes
    -q
    ANSI_ESC.TXT
    ANSI Escape Codes (Examples)
    Command            Foreground / Background
    prompt $e[37;41m = White            Red
    prompt $e[37;44m = White            Blue
    prompt $e[1;33;41m = High-intensity yellow    Blue
    prompt $e[1;33;44m = High-intensity yellow    Blue
    prompt $e[1;36;44m = High-intensity yellow    Blue
    prompt $e[1;37;44m = High intensity yellow    Blue
    prompt $e[1;37;46m = High intensity yellow    Cyan
    MAINMENU.BAT
    debug
    echo off
    :START
    cls
    cd c:\menu
    nocurs
    type mainmenu.doc
    :GET_RPLY
    reply
    if errorlevel 69 goto GET_RPLY
    if errorlevel 68 goto F10
    if errorlevel 67 goto F9
    if errorlevel 66 goto F8
    if errorlevel 65 goto F7
    if errorlevel 64 goto F6
    if errorlevel 63 goto F5
    if errorlevel 62 goto F4
    if errorlevel 61 goto F3
    if errorlevel 60 goto F2
    if errorlevel 59 goto F1
    goto GET_RPLY
    :F10
    normcurs
    cls
    goto END
    :F9
    goto GET_RPLY
    :F8
    normcurs
    c:\
    qd.bat ;(sample program)
    :F7
    goto GET_RPLY
    :F6
    goto GET_RPLY
    :F5
    goto GET_RPLY
    :F4
    goto GET_RPLY
    F3
    goto GET_RPLY
    :F2
    goto GET_RPLY
    :F1
    cls
    nocurs
    reply
    normcurs
    goto START
    :END
    MAINMENU.DOCPlease note: The above MAINMENU.DOC comprised of ASCII
    characters and is difficult to represent on a modern system.
    ASCII character codes used in the menu overlay:
    ╔ Alt-201   ═ Alt-205   ╗ Alt-187
    ║ Alt-186   ▒ Alt-177   ▓ Alt-178
    ╠ Alt-204   ╣ Alt-185  ╚ Alt-200
    ╝ Alt-188
    6,055
    I'm all for cute menu implementations; they are a good learning exercise.
    If space is a primary concern, this takes up less space on disk: http://www.vcfed.org/forum/showthrea...5191-Tiny-Menu
    (Because your menu relies on 7 files, there's no way it can take up less than (7*512)=3.5 KB.)
    Sep 2008
    SE MI
    4,124
    6
    Links to Tiny-Menu are no good. So, what's 3.5 KB? I been using this menu for 30 years or so on various DOS setups. I don't think I've ever run out of memory or disk space on any of my old DOS PC's. If you don't what to use it or at least try it, then that's up to you. It's a nice project for someone just getting in the hobby.
    Sep 2008
    SE MI
    4,124
    6
    Default MAINMENU.DOC Addendum
    For some reason the originally posted 'MAINMENU.DOC' produced an error:
    Mar 2017
    New Jersey, USA
    485
    In my experience the only part of any DOS menu system that needs to be tiny is the part that remains resident while whatever program you've chosen from the menu is running (which is the biggest benefit imo of batch-based menu systems -- the only resident part is command.com which will already be resident anyway). Ages ago I wrote a simple program using Turbo C to display a menu (with the names of the choices read in from a file specified via the command line), returning the user's choice via ERRORLEVEL. It ended up being used for lots of things, pretty much until we stopped using DOS boot floppies to set up newly unboxed PC's. The advantage of doing it this way was that the operator could choose an option using cursor keys and Enter (space and backspace also worked, in case the keyboard didn't have cursor keys), in addition to the 'normal' way of just typing the number of the row they wanted.
    I like Automatic Menu by Joel Gott. It only uses ~ 5k and it doesn't require any work at all to use it.
    Here's a synopsis:
    The AMENU utility (Automatic MENU) is a simple yet very functional menu
    utility. It was not designed to replace a "standard" menu program. Its
    purpose is to give you an uncomplicated means of viewing every executable file
    within a directory.
    AMENU scans the current directory and builds a menu for all .BAS, .BAT, .COM,
    and .EXE files. It also displays all subdirectories as well as the "parent"
    directory. All that is left for you to do is highlight the program that you
    want to run and press [ENTER/RETURN] or click a mouse button. It's that easy.
    AMENU also has a companion program called AMENUED.EXE. AMENUED allows you to
    customize AMENU to suit your tastes. All colors can be changed. Your own
    title can be displayed. Extension groups can be enabled and disabled. Various
    features used within AMENU can be enabled and disabled. Even the background
    pattern can be changed.
    AMENUED creates a data file called AMENU.DAT in the current directory. If at
    any time you want to return to the default settings of AMENU, then just delete
    this data file.
    Sep 2008
    SE MI
    4,124
    6
    Here's a synopsis:
    within a directory.
    this data file.
    That's cool and I like Direct Access too, but this is a learning experience and it's a lot of fun to do if you're just getting into this old DOS PC thing. No frills or extras, but you'll gain a fairly good understanding of how batch files work and get a taste of assembly on the side. It's really nice if you have a slew of games on your DOS machine as there's virtually no overhead.
    That's cool and I like Direct Access too...
    I also like Direct Access but that also requires some setup and a lot of configuration. AMenu is quick and clean -- as opposed to down and dirty. You just run it. In fact, it could probably be used in order to help setup the system you are promoting right here. And then you could just ignore AMenu or use it whenever it's deemed appropriate.
    Sep 2008
    SE MI
    4,124
    6
    REPLY.COM
    debug
    -a 100
    xxxx:0100 mov ah,8
    xxxx:0102 int 21
    xxxx:0104 cmp al,0
    xxxx:0106 jnz 10a
    xxxx:0108 int 21
    xxxx:010A mov ah,4c
    xxxx:010C int 21
    xxxx:010E
    -r cx
    CX 0000
    :e
    -n reply.com
    -w
    Writing 000E bytes
    -q
    BIGCURS.COM
    debug
    -a 100
    xxxx:0100 mov ah,1
    xxxx:0105 int 10
    xxxx:0107 int 20
    xxxx:0109
    -r cx
    CX 0000
    :9
    -n bigcurs.com
    -w
    Writing 0009 bytes
    -q
    NORMCURS.COM
    debug
    -a 100
    xxxx:0100 mov ah,0f
    xxxx:0102 int 10
    xxxx:0104 cmp al,7
    xxxx:0106 jz 10d
    xxxx:010B jmp 110
    xxxx:0110 mov ah,1
    xxxx:0112 int 10
    xxxx:0114 int 20
    xxxx:0116
    -r cx
    CX 0000
    :16
    -n normcurs
    -w
    Writing 0016 bytes
    -q
    NOCURS.COM
     debug
    -a 100
    xxxx:0100 mov ah,1
    xxxx:0102 mov ch,20
    xxxx:0104 int 10
    xxxx:0106 int 20
    xxxx:0108
    -r cx
    CX 0000
    :8
    -n nocurs.com
    -w
    Writing 0008 bytes
    -q
    ANSI_ESC.TXT
    MAINMENU.BAT
    debug
    echo off
    :START
    cls
    cd c:\menu
    nocurs
    type mainmenu.doc
    :GET_RPLY
    reply
    goto GET_RPLY
    :F10
    normcurs
    cls
    goto END
    :F9
    goto GET_RPLY
    :F8
    normcurs
    c:\
    :F7
    goto GET_RPLY
    :F6
    goto GET_RPLY
    :F5
    goto GET_RPLY
    :F4
    goto GET_RPLY
    F3
    goto GET_RPLY
    :F2
    goto GET_RPLY
    :F1
    cls
    nocurs
    reply
    normcurs
    goto START
    :END
    ╝ Alt-188
    There is a small error in the MAINMENU.BAT. Delete 'debug' (2nd entry) as it's a batch file and not compiled.
    You could have very easily edited the quoted material so all that superfluous stuff isn't quoted unnecessarily. It's much easier to make sense of a quoted post when it's not unnecessarily long.
    Thus:
    MAINMENU.BAT
    debug
    echo off
    :START
    cls
    cd c:\menu
    nocurs
    type mainmenu.doc
    :GET_RPLY
    reply
    goto GET_RPLY
    :F10
    normcurs
    cls
    goto END
    :F9
    goto GET_RPLY
    :F8
    normcurs
    c:\
    :F7
    goto GET_RPLY
    :F6
    goto GET_RPLY
    :F5
    goto GET_RPLY
    :F4
    goto GET_RPLY
    F3
    goto GET_RPLY
    :F2
    goto GET_RPLY
    :F1
    cls
    nocurs
    reply
    normcurs
    goto START
    :END
