Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: Just how good was the Windows 95 OSR 2.x USB Supplement?
    34,970
    18
    As I seem to recall, the DOS/Panasonic doesn't allow for "hot plug" of USB memory devices. That is, if you want to change the USB device, you have to reboot.
    Win98SE does understand the Windows Minidriver concept, which is primarily why I don't bother with any flavor of Win95.
    How's the support on WinME?
    If loaded vis config.sys, yes, you are quite correct.
    But if loaded via loadsys.exe you can change USB drives at will:
    https://www.hiren.info/downloads/dos-files
    I use this regularly, as well. This eliminates the need to reboot as it's an on-the-fly device driver utility. I kinda like them and I use a stand alone XMS/EMS RAM disk that is installable and resizable from command line without needing to use loadsys.exe.
    With loadsys.exe you can load/unload virtually any device driver or TSR at will without a reboot being necessary.
    34,970
    18
    Does this interfere with the GUI on Win9x? Does it support USB drives in excess of 8GB?
    I am able to use 8 GB and 16 GB drives with it.
  5. #15
    34,970
    18
    I'll give it a try--thanks!
  6. #16
    I use USB flash drives on my DOS tweener regularly using the Panasonic support mentioned by krebizfan.
    Yep me too, works very well, The panasonic drivers are not so good with UHCI, But the Iomega drivers work fine with UHCI but use more memory.
  7. #17
    While you're at it, i.e., experimenting , let us know what other drivers and TSRs you were successful or unsuccessful with. I've only tried loadsys.exe with those USB drivers.
  8. #18
    34,970
    18
    I assume that loadsys doesn't have problems with drivers loaded high.
  9. #19
    Quote Originally Posted by Malc View Post
    I am able to load di1000dd.sys high on my tweener.
  10. #20
    You know, I haven't yet tried that so I'll be waiting with bated breath to see what you discover. Since it's unloadable it didn't seem too relevant to me. It gives the entire 14k back when unloaded.
