Page 38 of 43 FirstFirst ... 28343536373839404142 ... LastLast
Results 371 to 380 of 424
Thread: Commodore pet 3032 screen full of lines
  1. #371
    Jun 2012
    UK - Worcester
    3,155
    Yup.
    I suspect the RAS signal we are seeing is the refresh but there is no RAS for the memory access. That's as I understand the two halves of the 7474 work at any rate.
    And one of the duff signals also feeds into the video sub-system to boot...
    Quote Originally Posted by daver2 View Post
    Yup.
    Good evening,
    164 has just arrived....now i change...
    what measures do I still have to take?
    thanks!
  3. #373
    Wowwwww!
    Who's that???
  4. #374
    Quote Originally Posted by ilpaninaro View Post
    Wowwwww!
    Who's that???
    Now pettest seems to work!
    But i don't know if it is ok....
    The words on the screen tremble.....
    This is a little video:
    https://youtu.be/prbvrh6HJx8
  5. #375
    Looks good to me.
    Dwight
  6. #376
    Feb 2009
    Southern California, USA
    2,692
    Wowwwww!
    Who's that???
    It passed the quick RAM test and did a sum check on the ROMs.
    If you like, you can replace the pettest rom with the EDIT rom and see if it boots. We may need some more testing.
  7. #377
    May 2018
    Lancashire
    260
    What a massive step forward
    Top remote diagnostics Dave !
  8. #378
    Quote Originally Posted by dave_m View Post
    Hi, i replaced Pet tester with the original edit rom but when i turn on pet, i can see only black screen
  9. #379
    Feb 2009
    2,692
    Quote Originally Posted by Gary C View Post
    Yes, daver2 did great job. Kudos for skill and patience.
  10. #380
    Feb 2009
    2,692
    We’ll need to check the recorded checksums from pettiest vs the known good values, as a ROM maybe bad. I forget, do you have new ROM installed or originals?
