Page 3 of 38 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 375
Thread: Commodore pet 3032 screen full of lines
  1. #21
    ok thanks.
    So g11 pin 4 is bad.
    Can you check the following pins for pulsing with your logic probe please:
    G10 pin 6 (74ls00).
    G10 pin 8 (74ls00).
    G9 pins 8 and 9 (74ls74).
    E11 pins 7 and 9 (74ls165).
    Basically, i am working backwards on the schematic diagram until we find where things go from good to bad...
    g10 pin 6=pulse
    g10 pin 8=pulse
    g9 pin 8=pulse
    g9 pin 9=pulse
    e11 pin 7=pulse
    e11 pin 9=pulse
  2. #22
    Quote Originally Posted by ilpaninaro View Post
    Sorry but i think that problem in this pet are the Rom....
    I tried to insert Pet tester in ud9 with only char rom inserted and i can see this double Attachment 55992Attachment 55993screen:
    That is good easter eagging but not good trouble shooting for reference to others. It would be better to finish trouble shooting with Dave for others looking at this thread. I suspect your right, blowing a set of ROMs will likely help. What do you mean by double screen?
  3. #23
    Double screen cause pettester show 2 alternates screen
  4. #24
    I guess I have to be a Pet person to understand. Nice to have an alternate screen.
  5. #25
    2,978
    >>> Double screen cause pettester show 2 alternates screen.
    No idea what you are talking about?
    Ok, with the PETTEST ROM in the kernal ROM socket you are getting video. Is that what we are saying? There is a small probability that the video screen had been erased completely but the code has crashed befor it has had a chance to display any meaningful characters on the screen. My test process would have identified that scenario if you had followed through with it...
    The 'first' screen indicates that page zero RAM is all bad/faulty (hence the b's). You need to explain further what the other screen of garbage is that you have shown. Does it alternate with the screen of b's? If so, at approximately what frequency?
    Hi Dave,yes the other screen it alternate with "b" screen every 2 secondos more or least...
    I ve also changed bad roms with new eprom and now i ve again black screen
  7. #27
    2,978
    So, we at least know that the video circuitry appears to work.
    Can you download my PETTEST code, burn it into a 2K EPROM, put it in place of the EDIT ROM and plug the kernal ROM in please. What do you see on the screen?
    You'll have to lookup my google drive reference on the VCFED Commodore thread though. It is currently version 4. This is an extended PETTEST than the one that lives in the kernal ROM socket and can test the video screen, page 0 and 1 of RAM, the keyboard and ROMs and a more extensive memory test of all of the RAM.
    EDIT: Here https://drive.google.com/drive/mobil...13&direction=a.
    Just a thought about your double screen. Is it possible that the character generator is faulty. I know you said that you have got the correct checksum, but if it is faulty you could get a screen of capital B's that get converted into random rubbish. I do, however, have a test for this scenario if your video RAM is socketed...
  8. #28
    Unfortunately now i don't have a 2716 eprom...can i burn your pettest on 2732 maybe?
    Thanks
  9. #29
    Feb 2009
    Southern California, USA
    2,662
    Thanks
    Yes, but burn the 2K code into the upper 2K address space from 0800 Hex to 0FFF Hex. In other words use a 0800 Hex block size (2048 decimal) and a transfer start address of 0800 Hex. Does that make sense to you?
  10. #30
    With bad zero page RAM, it is not likely to do much on the video out. Almost everything needs good page0 and some page1.
