Page 42 of 43 FirstFirst ... 32383940414243 LastLast
Results 411 to 420 of 425
Thread: Commodore pet 3032 screen full of lines
  1. #411
    Now we are on pass 00007 and it's ok....
    but screen are disturbed....words wobble and flicker on the screen...
  2. #412
    3,178
    I don't care about the screen wobbling at this point in time - we are testing the RAM for now. Can we concentrate on one problem at a time please.
    Let's get to memory pass 20 without an error and we can then move on from there - but pass 7 without an error is looking promising.
    Can you remember which pin was bent?
    Ok, maybe pin number 9
    Now screen show pass 0000c.
  4. #414
    3,178
    Pin number 9 = +5V supply. That definitely wouldn't have done the memory chip any good !
    Excellent. Keep going...
    DAVER2 now we are at 000026 pass......can i stop?
  6. #416
    3,178
    Yep, you can stop now. That looks good to me.
    The next thing is to test the keyboard PIA and keyboard itself.
    Reset the PET and get the ROM checksum and keyboard test screen up with the count down counter ticking away.
    Press each key in turn on the keyboard - and you should see a single '1' bit appear for each key pressed. If you don't get a '1' displayed then it is possible that the key is not working correctly, or there is something wrong with the row/column matrix logic.
    When you have done that report your findings back please.
    If the counter counts down to zero (and starts the memory test) before you have finished your key testing, you will have to reset the PET again.
    Daver2 keyboard works correctly....i
    I've already tried all the keys on the basic screen
  8. #418
    3,178
    OK,
    PETTEST out of EDIT socket and EDIT ROM back into EDIT socket.
    Test PET with BASIC and see what the 'bytes free' message says.
    Yes!!Finally!
    I found the last culprit!
    Looking at the ram schematic, I tried to piggyback the two 244s and fortunately I saw that with one of these, the defect disappeared..
    so i changed UH10 and now i have all ram size and not disturb or noise
    Daver2 thanks so much for your precious help and thanks to the other members!
    Now another Pet alive!!
    Daver2 excuse me but i must open another post unfortunately.....i have a 8032sk 100% workling but monitor board don't works and i can't see anything at screen
  10. #420
    3,178
    Good news!!!
    No problems. Enjoy your machine...
    I assume you mean UI10 rather than UH10?
    It is interesting why UI10 didn't appear faulty when we were doing the memory testing - as it buffers data lines 0 through 3?!
    Presumably that cured the screen issues as well did it???
    I remember that machine. I will let someone else have a go at that whilst I get on with another project.
