Results 1 to 4 of 4
Thread: Help deciphering Supersoft results on 5150
    Sep 2019
    Cambridge, MA
    Default Help deciphering Supersoft results on 5150
    Hi all,
    I have a 64-256KB 5150 motherboard that is failing the critical memory test with the Supersoft diagnostic ROM. Iíve removed all chips from banks 1-3.
    According to http://minuszerodegrees.net/supersof...64KB-256KB.htm I should expect failures past memory address 10000 (64K). Supersoft is also reporting memory errors at these addresses:
    04000
    0c000
    14000
    1c000
    24000
    2c000
    34000
    3c000
    44000
    4c000
    54000
    5c000
    64000
    6c000
    74000
    7c000
    84000
    8c000
    94000
    9c000
    00000
    08000
    The diagnostic summary shows the total errors as 3 when the first pass completes. All other (non-memory) tests passed. Iíve read through the memory test section of the Supersoft manual a few times, but Iím not understanding how to interpret these results. Would I be correct in assuming that all 9 chips in bank 0 are bad?
    6,309
    Expect a screen similar to that shown at [here]. That screen was produced when I simulated a failure of bit 2 in bank 0. Note the row in the bottom-right labeled "FAILING BITS" and how in that row, bit 2 is marked with a cross.
    6,309
    Consider too the use of Ruud's diagnostic ROM. See [here].
    The kind of output expected from that for failed RAM bits is shown at [here].
    Sep 2019
    Cambridge, MA
    Yeah the failing bits were kind of all over the place throughout the test. I had to record a video because I couldn’t write them down fast enough. I didn’t know about Ruud’s diagnostic ROM, I’ll check that out too.
    Thanks
