Results 1 to 10 of 12
Thread: X10 Home Automation Modules (Attn: TRS-80 CoCo users)
    Default X10 Home Automation Modules (Attn: TRS-80 CoCo users)
    There was a X10 home automation module for the TRS-80 CoCo. I have listed some modules that some owners may be into. Think other platforms also had some control units like the CoCo,
    http://www.ebay.com/itm/264404860729
    The CM11A controller is RS232 and works on any machine with RS232. There are newer modules that work with modern "PCs" over USB.
    The parts you are selling will work with, but don't require a computer. So they are useful to anyone who wants to play with this interesting technology.
    5,819
    44
    X10 is a total blast.
    If you can get around having to De-noise your house wiring (mainly EMI from cheap or poorly designed power supplies in electronics and AC adapters that didn't exist in the past) you can control just about anything without having to install hardwrired or IoT modules and controllers. The only big drawback is it's a unidirectional protocol with no signal protection, so don't be stupid and hang stuff like locks, coffee makers or other appliances you typically wish not to possibly be accidentially turned on.
    Otherwise yeah, the tech is almost 40 years old and pretty much every computer platform had an X10 interface or control software.
    = Excellent space heater
    Oddly I got an email from X10.com (the really shady website that's legitimately associated with the real manufacturer (IP holder?) just today telling that you can now control X10 from your smartphone!
    De-noising the power lines is something that needs to be done anyway. It clears up a ton of other mystery problems with WiFi and cell phones and anything else wireless. Plus your radio-listening neighbors will much appreciate it. And, at least in the US, it's the law. Most people are oblivious of all these things.
    5,819
    44
    X10's always been kinda shady since the late 90's when they started putting up those "this tiny camera can go ANYWHERE" banner ads (come on, I know we've all seen them) on websites and their core market was pervy men. X10 automation has not been an innovator for a long, long time.
    Jun 2015
    Sioux Falls SD
    349
    I bought their stuff starting around their introduction and finally retired the last pieces about 10 years ago. It was great early on. I even had a TRS-80 Model I console with an EPROM mapped in the empty space between ROM and RAM that would boot into a control program for the X-10 I wrote in assembly language. Much better than the clock they offered, and was quite reliable. I hated the lack of two-way communications, and so as Z-wave and WiFi control modules started coming out, I switched.
    I regret losing that TRS-80, and then getting rid of the Apparat EPROM burner.
    I *think* you can get Leviton branded X10 modules that are two-way. I seem to remember programming for them.
    Jun 2015
    Sioux Falls SD
    349
    Forgot about those. They were very pricey IIRC.
    Yes. At least twice the price of equivalent X10 branded modules. But if the specs are correct, they were well worth the cost. Much more versatility than, yet full compatibility with, the X10 stuff. Decora was the brand name, I think.
    Pretty much all X10 (even the Insteon and Leviton stuff) is problematic. I know all the ways to make it work better. Pretty much the more you add to worse it gets (black holes) and the older it gets the worse the performance. Add things like modern electronics and the AC environment becomes even worse. I finally gave up on all power line communications. I actually have the RS CP290 (also the CM11A, PL513 and TW523). I once had the Heathkit Computer interface (like the PL513).
