2 2.4ghz cpu's can rate significantly higher then 2 3.3ghz cpu's, and that difference seems much more significant given the difference in clock speeds. But games still favor higher clock speeds, correct? I've left core counts out of the discussion, I guess you can't. But games still run faster (fps or whatever) with lower core counts but higher clock speeds? I'm looking at dual 2011 cpu's currently.
