Results 1 to 7 of 7
Thread: Looking for a 6502 assembler cross-compiler
    Dec 2011
    East Coast USA
    821
    Default Looking for a 6502 assembler cross-compiler
    that I can run on my modern MacBook Pro (OSX Mojave). I have a bunch of 6502 assembly work to do and it might be a little painful to keep going back and forth to my real machine. Figure I can assemble on my Mac, test on an emulator and then move the code to the real thing.
    Any suggestions?
    Thanks,
    Corey
    4,119
    I use the online https://www.asm80.com/ assembler. If you name your files .a65 it works with a 6502 CPU. It contains a little simulator and debugger as well. I have developed my PETTESTE2K PET TEST EPROM with it. Seems to work really well.
    My iMac is my real machine... I do run parallels for FPGA software (until the manufacturers work out that there are other platforms other than Windows) and DOSBox for other 'old' .COM and .EXE files that I use as well.
    The CC65 suite contains an assembler, C compiler, linker, and Apple 2 runtime library.
    The assembler also supports the 65816, but the C compiler does not (so no //gs C software).
    https://cc65.github.io/doc/apple2.html#s2
    I'm terribly biased, but http://www.floodgap.com/retrotech/xa/
    Various projects and oddities: http://oldvcr.blogspot.com/
    Outer Mongolia
    3,084
    I used CHC's xa to develop the original creaky 2011 version of Pettester, so I'll vouch for it.
    Just to complete the "picture": http://john.ccac.rwth-aachen.de:8000/as/
    This one supports a lot of different architectures (including of course the 6502 and derivatives) and should be working on OSX too.
    Frank IZ8DWF
    My go to is Merlin 32.
    http://www.brutaldeluxe.fr/products/...vtools/merlin/
    I lack a modern MacBook Pro (OSX Mojave), if I had one, I would build it for you. I've done builds using a PowerPC Mac (Mac OS X 10.5 Leopard.)
