Results 1 to 10 of 23
Thread: Replaced barrel battery and keyboard is locked
    Sep 2016
    Shrewsbury, MA
    1,047
    Default Replaced barrel battery and keyboard is locked
    So I just replaced the barrel battery on a motherboard I'm using for a build and now when I turn it on, it says "keyboard is locked". I don't have a keylock switch connected and it didn't say anything about it beforehand. Any suggestions? I'm going to leave it plugged in for a few hours and try again when the battery has some charge
    Did you solder anything?
    4,457
    Did you disconnect a wire while disassembling? It might just be that one wire is connected backwards.
    Sep 2016
    Shrewsbury, MA
    1,047
    All I did was desolder the old battery and solder a stock replacement in its place. I checked and the connections are good. After leaving it on and letting the battery charge, it now posts and freezes before it checks the ram. Possibly bad cache? The ram came out of a working machine last year
    Sep 2016
    Shrewsbury, MA
    1,047
    This is where it freezes, just replaced the ram and cache with known good replacements so it's not that.
    It's not those connections I was intimating about. It's the possibility of unintended/unwanted ones. You may now have a renegade trace somewhere.
    What caused you to bring cache into this matter?
    ... it now posts and freezes before it checks the ram.
    How's that? The RAM is checked during the POST.
    32,682
    Well yes and no--the first 16K of RAM is checked before displaying anything, then the remainder of the base 640K, then the CPU switches into protected mode to check the extended RAM area. But the display is obviously getting initialized, so at least it's getting pretty far.
    The Supersoft ROMs may provide some insight.
    5,815
    44
    Given how close the keyboard controller is to the location of the barrel battery on most old motherboards I also suspect that there are more prominent problems attributed to trace corrosion.
    = Excellent space heater
    Sep 2016
    Shrewsbury, MA
    1,047
    I tested all affected traces and all seemed to be good. I just went over with a magnifying glass and found a little corrosion on one pin of the bios chip but cleaning it didn't change anything. I thought the issue might have been cache because I've experienced some very strange issues in the past when that goes bad.
    Why did you wait until post #9 to mention corrosion?
    Did you check the traces on the inner layers?
