Page 10 of 10 FirstFirst ... 678910
Results 91 to 98 of 98
Thread: Original Tandy 1000 no boot
  1. #91
    Jan 2011
    Vancouver, BC
    5,160
    3
    Yeah the tops of some of the legs of the ICs have some surface rust, but the legs themselves seem to be fine and same with sockets where applicable. Hopefully the two controller chips get here soon and maybe that ends it there.
  2. #92
    Feb 2017
    Chilliwack, BC, Canada
    566
    Can I confirm that the first chip you replaced, the 74LS32, is U98 and not U58? U58 is half way across the board from this circuit, next to the main oscillator.
    My vintage systems: Tandy 1000 HX, Tandy 1000 RSX, Tandy 1100FD, Tandy 64K CoCo 2, Commodore VIC-20, Hyundai Super16TE (XT clone), and some random Pentium in a Hewitt Rand chassis...
    Some people keep a classic car in their garage. Some people keep vintage computers. The latter hobby is cheaper, and is less likely to lead to a fatal accident.
  3. #93
    Jan 2011
    Vancouver, BC
    5,160
    3
    Yes it was u98.. closer to the FDC.
  4. #94
    Feb 2017
    566
    Alright, about where was the trace that got damaged initially, and what was it connected to?
  5. #95
    Jan 2011
    Vancouver, BC
    5,160
    3
    Okay so I got a replacement FDC9216 (or was it 8216) chip, and it boots! Fantastic! Thought I could finally put this together, get it off my bench and carry on with my play space renovation.
    Buuut..
    Now the keyboard doesn't work. The num and caps lock keys don't light if you press them, and when it finishes booting, if the keyboard is plugged in it starts going nuts producing random junk. Ugh! I don't think anything I was working on was in the vicinity of the keyboard circuit.. at least, going by the schematics. Hmmmm
  6. #96
    Feb 2017
    566
    It's 2020. Nothing is simple anymore
    At least the floppy is working now.
  7. #97
    Jan 2011
    Vancouver, BC
    5,160
    3
    Interesting.
    I had a last minute thought. I swapped the old FDC chip back in. Drive stopped working, but keyboard worked! Wha...
    Luckily I bought 2 FDC chips.. plugged the other one in.. now it all works... weird.
  8. #98
    Feb 2017
    566
    That's interesting. I don't see any obvious relationship between the two other than the data bus. But the floppy was booting, so the bus is obviously working. I hope here isn't an intermittent crack in the board somewhere.
    But hey, everything's working now! Maybe 2020 isn't a total loss after all?
