Page 2 of 10 FirstFirst 123456 ... LastLast
Results 11 to 20 of 98
Thread: Original Tandy 1000 no boot
    Jan 2011
    Vancouver, BC
    5,092
    3
    I've tried the floppies that came with this machine in another machine.. one has mechanical issues.. the other is a bit strange.. I have it set as drive a.. but when I try to access drive a with it connected to one head of the double floppy cable, it spins without reading or lighting up. If I connect to the other header on the cable, it lights up but does not spin.
    I must be forgetting something about floppy drive jumpering?
    Jan 2011
    Vancouver, BC
    5,092
    3
    Looks like I have bigger problems. I went to power up the 1000 after figuring out the jumper settings on one of the two drives. But now instead of getting a post, I get a blank screen and a continuous screeching noise from the speaker. Ugh
    Jan 2011
    Vancouver, BC
    5,092
    3
    This is what it is doing now:
    https://youtu.be/yZtWFSJkP_s
    Mar 2016
    Georgia, USA
    673
    Spunds like unmuted Tandy sound chip random noise. I believe your bios is not being seen or is corrupt, muting that chip is one of the first things it does I believe.
    Jan 2011
    Vancouver, BC
    5,092
    3
    I wonder if I could borrow the bios chip from my working 1000ex to test that?
    Mar 2016
    Georgia, USA
    673
    I don't know. I doubt it would work.
    Jan 2011
    Vancouver, BC
    5,092
    3
    Apparently it does. The 1000 ROM worked fine in the EX. But changing ROMs in the 1000 does not produce anything.
    A couple of times on power up I got some 'snow' on the 1000..
    If I had to lay a bet, I'd bet it was something to do with memory.
    Outer Mongolia
    3,083
    Did the 1000 ROM recognize and use all 256k built in RAM in the EX? If so that's... interesting.
    Jan 2011
    Vancouver, BC
    5,092
    3
    No... it only sees 128K.
    Jan 2011
    Vancouver, BC
    5,092
    3
    Okay so I have done some checking around. Voltages from the PSU look good. I see clock signals being divided into correct frequencies ok. But there is no activity between the CPU and 128K ROM. I have light 'snow' on the screen, persistent tones from speaker.
    One thing that is odd.. probing the READY line on the CPU it it is high, however if I hit Reset a random number of times I will sometimes see an inconsistent signal there.
    Presently am trying to understand how the 8284 works and why occasional reset causes it to 'leak' signal onto the ready line, or if something should be there.
