Results 1 to 10 of 11
Thread: Help to open monitor PS/1 P/N 93F0503
    Default Help to open monitor PS/1 P/N 93F0503
    Hi.
    I am trying to open a monitor of a PS / 1 2121. I want to open to clean and see that everything is correct before turning it on.
    Remove 4 screws and the base but I am not able to remove the cabinet. Does anyone know if he has any particular lock or something?
    Thank you!
    Quote Originally Posted by Franchute13 View Post
    I want to open to ... see that everything is correct before turning it on.
    What would you be expecting to be able to see?
    Hi.
    Thanks for answering.
    This monitor has the PS/1 PSU inside. This PSU has a cooler. I want to see if it is in good condition and clean it.
    Regards.
    32,489
    Look at "monitor disassembly" here
    The monitor is a different model. There are no screws under the base.
    32,489
    Okay, I tried. VCF member vwestlife is pretty familiar with the PS/1 stuff. Why not shoot him a PM and see what he has to say?
    Okey
    I have not taken apart the monitor. Sometimes there are screws hidden under the label or rubber feet.
    There may be covered recessed cutouts where the screws are hidden.
    Hi.
    I could not disassemble it, so I left it as it was, I tried to have good output voltage and use it until it can.
    Here is a picture of the monitor and the PS/1 2121 (386sx 16mhz, 6mb ram, 40mb).
    Thank you all.
